Official 00-06 Tahoe/Yukon/Escalade drop guide with pics...
04charcoalhoe
Just ordered the 3-5/6 kit with the adjustable panhard bar now I just need to find some stock spindles
Fosscore
^^ @crazycrew
go with the 295/35/24 that's what I am running. Measurements are negligible except for the sidewall. It makes a huge difference in looks overall tho especially that low.
:2cents:
crazycrew
Vacherie, LA
Yeah, I've been researching the sizes. . Idk. Going to that drop kit is at least double the price.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Dirty-hoe
Here is my tahoe it has a djm 2-3 drop with keys and coils and shock extenders 20 with 275 55 20 tires
04charcoalhoe
@Fosscore, what kind of measurements do you have from ground to fender on fronts and rear? And you are 6" in the rear and 3" lca's and de-crancked a bit in the front right?
NeverSatisfied
eBay Baller
Wichita, Kansas
Wheel/tire size
I'm trying to decide between Tony's 2/4 with 22 and 285/45
or the 3-5/6 with 24s and 295/35
If I had to do it all over again on mine I would've went with 285/40/22s on my 375s and if I had 24s I would've definitely went with 295/30/24s. Both 31" tall, reason being for a little more clearance and ride wouldn't have suffered much if any.
04charcoalhoe
@Fosscore Ok cool. Just put the exact same kit on , but I left the 1" spacer in the rear. Looks like I'm gonna need to pull that out. You think it will effect my alignment if I pull those out after I get it aligned? I don't think I'm as low as you in the front. How much do the rear springs settle and roughly how long does that take. I'll get some pics up soon.
Fosscore
Should be no effect on the alignment pulling the spacers. Can't recall on the rear springs, but that free travel mod is must if you haven't done it. It will ride like crap if you don't cut that bump stop off. That is more key than the spacer or the springs in the rear. @04charcoalhoe
04charcoalhoe
Yes definitely did the free travel mod. Getting alignment tomorrow.
24" TBSS wheels 295/35/24
Kit I used..
FRONT:
DJM 3" LCA's
Torsion keys de-cranked a bit
Front belltech street perf shocks
New factory jounce bumpers
REAR:
Rear 6" Spring/ 1" spacer (which I will be removing)
DJM rear hardware kit
DJM shock extenders
DJM endlinks
DJM bump stops
Free travel mod
Sphoon adjustable pan hard bar.
Air lift bags
Rear beltech street perf shocks
@Fosscore
04charcoalhoe
@Fosscore how far away are your rear bump stops from touching in the rear? With the 1" spacer in the rear and the free travel mod done it looks like I'm only 2 to 3" at most from touching now.
Korbin_A
