Much better oil pressure after oil change.
OneofFew
Talullah Falls, Ga
Background: 245k miles, bought neglected, sat a lot and oil was well overdue for changing based on time.
Not long after the 1st oil change I had to replace the oil filter again due to oil pressure drop offs. After changing the filter, all was well. I have been using Mobil1 10w30 synthetic and the A/c delco oil filter. PF47 I think, switched to the larger capacity PF61 after the initial oil pressure drop off issue. The second oil change occurred within 3k miles as it seemed to be accumulating debris.
now that I have put about 15k miles on it, it is becoming clear that my oil pressure is much better right after an oil change and it starts to drop off pretty quickly after. I have been changing the oil at 5k intervals since.
Initial oil pressure is around 40psi hot idle and 55psi at 2k rpm. It does not take long for the oil pressure readings to drop to 25/40 respectively with some fluttering of the needle.
The only thing I can think of is that the oil is getting diluted, but I don't see any evidence of a fuel injector leak. The oil seems fine when I change it. I may have to pull the spark plugs to check for indications of an injector leak. No Mil lit. Fuel mileage is always around 15mpg with a 5.3 4x4 with 50% highway, 50% windy mountain roads and dirt roads, some requiring 4x4.
mattbta
Frisco, TX
Any leaks? I think my rear main is leaking as I have noticeable oil under the truck and everything but that has been replaced. I also noticed oil pressure drops significantly after 400-500 miles after an oil change. I'm thinking it is due to the leak. I need the check my level and see if it is getting low and top off to see if pressure rises.
I would send a sample to Blackstone Labs for analysis. They may be able to shed some light on it.
Larryjb
Pop off your valve covers and look for evidence for cracked heads. These symptoms are very similar to mine. Now I have rebuilt heads and oil pressure stay up for the duration of a normal oil change interval.
I didn't realize this at first, but a small coolant leak involving Dexcool causes oil sludging, not milkshake oil.
OneofFew
OneofFew
Talullah Falls, Ga
I do need to replace the valve cover gaskets anyway, so I may do that soon. It has not been using coolant at all, so I doubt any coolant is getting into the oil. After 5k miles, the oil seems to be in good condition, no sludge, just a bit dark- which I attribute to washing out of old debris from years of neglect.
But as I said, I will pop the valve covers and check for sludge. Thanks for the suggestion.
OneofFew
OneofFew
Talullah Falls, Ga
I add maybe a quart between oil changes, which I think is good. It doesn't leak more than a few drops, but I have never heard of an oil leak reducing oil pressure unless the level drops way low to where the pickup is drawing air.
OneofFew
OneofFew
Talullah Falls, Ga
If I was adding more oil between oil changes and the pressure drop was more linear over time, I would suspect engine blow by diluting the oil with fuel.
That would probably be a good idea. If there is fuel/oil dilution beyond the typical rates, it would definitely show that.
Also will tell you of any unusual engine wear ie bearing material, coolant, silicones, etc. They're very thorough.
Larryjb
Take a look at post #31. This what you could be looking for. It's not a fast leak, so you might not notice any coolant loss before it sludges in the sump. The filter would prevent sludge from getting back to the heads.
HiHoeSilver
Away!
Chicago
There are only 10 posts. What #31 are you talking about?
Reane
I had the same issue in my 08 Yukon 6.2l it would get great pressure right after a change and then it would gradually loose good pressure. ended up with the rear seal leaking fixed it and all better!
OneofFew
OneofFew
Talullah Falls, Ga
Thanks. I will investigate this. When I bought it, it had an overheating condition that turned out to be a clogged radiator. The PO had green ethylene glycol coolant in it... no coolant in water then. Nor slime on the oil filler cap as you would expect when excess moisture was in the system. I have since replaced the radiator, water pump (was squeaking but worked) and thermostat (was missing) and put dexcool back in it after a good flush. I'll do the oil analysis after putting some miles on this fresh oil and pull the valve covers.
Any suggestions as to how many miles I should do before the oil analysis?
According to these FAQ’s they recommend at least 500-1000 miles. I’d order the kit now so you have it, the kit is free. They don’t charge until they do the analysis.
https://www.blackstone-labs.com/information/faqs/gas-diesel-questions/
Larryjb
I should add that I pressurized the cooling system with a pressure tester. This, in combination with an oil analysis, confirmed the crack was the source of the water in the oil.
brasil
as far as I know, there is a little o-ring at the end of the tube that ends in the sump. if this o-ring is rotten...you will loose some of your oil pressure . The strange thing is, that the pressure loss occurs 400-500 miles after you changed your oil. this speaks for bigger clearances between the bearings. so I would go with a 10-40 ..or 10 -50 Oli. and watch for the drop...
if the oil pressure stays in a good range. you´re done. If not.... remember the o-ring
Greetings Juergen
Larryjb
I would be cautious about using any viscosity above 10W30. You want lubrication to the lifters as fast as possible. I sometimes get lifter noise on start up. As soon as I went to 5W30 the lifter noise quietened much sooner.
I think your engine is just sludged from the previous neglect and the good oil/regular oil changes is breaking up the sludge and it's clogging up the filters. You may just have to keep replacing the filters until it's cleaned internally.
But, just to throw in something from far left field:
Say your engine is sludged and chunks are breaking free since you've been taking better care of it- Higher quality oils contain detergents that can help to dissolve the sludge. The screen on the pickup tube is getting clogged as it sucks up the chunks from the sump. You drain the oil and they fall off the screen and settle back to the bottom of the sump or flow out of the drain hole. The oil pressure is then good again until that fresh oil breaks up more sludge that ends up in the oil pan and the cycle continues.
dizhai
