Lifted/Leveled 2021 - Postem Up
REF0603
Montgomery, TX
agreed, i would probably push an after market arm.
i have been meaning to ask a family member, but i do believe he is personal friends with the owner ship of Hurst.
That’s pretty cool. If you get a chance to ask, I would love some info.
I also found this today while searching for an already engineered 4” lift.
It’ll crank up to 4.5” but I think that might be a lot.
This is what it looked like on a customer build. 24s on 35s
olyelr
Elk Rapids, MI
4.5” lift with no dropped diff or lower arms?! Ummmmmm, nah. I can hear the ball joints and axleshafts crying from here…just at ride height.
nick14226
Something I've noticed with the RC and Readylift, no diff drop spacers. Asked Readylift about it and they said they're not necessary with the current gen geometry. Eek, I don't know.
Readylift seems to sit more level at their 3" lift and only have preload spacers in the rear. RC 3.5" has preload spacers in front as well, so could be a bit stiffer ride overall and tend to look nose high in a lot of pics to me. The 2" RC I have is slightly nose high as well, but not enough to bother me too much. Readylift also has some wiring/cable relocation brackets for the front where RC doesn't, so seems to be a bit better thought out.
I'd love to go higher but want to see a few 21-ups with these kits and higher miles to see how things are going.
nick14226
Someone had posted pics of the trimming process Hurst does to clear 35's. They hack away A LOT at the front and rear of the fenders, I was both terrified and impressed. Wonder where the heck I saw that...
ProfeZZor X
High Country
I have the Ready-Lift 3" SST lift, and it's the right amount of lift for me without compromising parking garage clearances. with 33's and the 3" lift, my height comes in at around 6'6".
Hunter Linn
Tuscaloosa, Alabama
Hey Guys,
I just ordered the RC 3.5" lift and 35x12.5x20 tires. I want to use it on my stock Z71 20" wheel. Do any of you know what size spacers I will need to prevent rubbing UCA, inner fender, ect. I do not want them to stick out far. Just enough to not rub.
STORMIN08
i would do the thinnest bolt on specer you can get...1"
i have seen 1.5 and 2, both protrude more than i would care for. i like to mine to be covered by a STREET FLARE if needed, so no more that about 3/4" out of the fender.
Hunter Linn
Tuscaloosa, Alabama
Thank you, I’ll go ahead and order that too. Hopefully I’ll have it all on in the next week or two.
nick14226
Would check how deep the pockets are in the wheels you have, your studs are going to stick out a decent amount with 1” spacers (unless you’re willing to trim them).
I’m running 1.25” bora spacers and they clear but it’s close without stud trimming.
Hunter Linn
Tuscaloosa, Alabama
I was looking at running the 1.25" Bora spacers as well. It should fit. If it does not, I have no issue with trimming.
nick14226
With that said I’m only talking the studs, only assuming the 1.25 are enough to clear UCA’s. And think you’re going to have a decent amount of fender work to fit 35’s.
Dh1280
