LH Rad support bracket on frame
Czykats44
Dis Member
Glenville, NY
Mine is looking a little desperate so I picked up a replacement part, prepped and coated it. I haven't had an opportunity to swap it out yet but looking at it I noticed what looks like two small beads along the bottom.
Is there a sealant there or are they bolted AND welded from the factory?
I believe that those are tack welds, probably used in the assembly process to 'hold' the part in place, until the bolts were put in to complete the attachment process.
YukonGTmaster
2 Door w/ Barn Doors Club
A bit off topic, but you could do yourself a big favour and treat some of the rust at your frame. I did a rustoration on my 97 Yukon in the summer, and was introduced to “Corroseal”. It is a rust converter that you can brush or spray on. It turns rust into a hard black “Magnetite” which stops the electrolytic process the rust needs to grow. I hit my frame with a wire wheel to get any larger scale off, pressure washed it and brushed the whole frame with the corroseal. Then I painted it matte black with a rattle can. Just thought I would share.
Thank you for sharing. Our collective knowledge base has been increased.
Bob LaFord
