Just Fishing
Can't fix stupid
Took it for a quick little drive, it's better.
1-2 was being all flare. but that's gone now
Open the door for like 10 seconds, and close it, with the key out of the ignition. That supposedly resets whatever needs to be resetFound a nice video telling me how to get the fast learn to fire off using HP Tuners
Adding the FastLearnStatus, it gave me directions to place in Drive.
then a nice status as it did it's thing.
Now i'm stuck in between gears, but that's normal.
IIRC I just need to wait it out.
You could bring the lower cover to an upholsterer. They could replace just that one panel--it's vinyl, so it shouldn't be much.and the picture of the freshened seat.
Last night I used my steamer to try and get some of the wrinkles out of the leather.
Much better than it was for sure.
Due to the little repair on the side, I was tempted to replace the cover.
but I opted to use the current one instead, saving me some money.
+ I like the aged look of the leather.
But after I made the order, I find out about these little plastic gears in the seat lumbar that strip out over time.
And I can hear the motor buzzing, but nothing adjusts.
that same company makes little metal gears to replace the plastic ones.
I repaired the gears in my drivers seat. Will see if I can dig up the info.My lumbar hasn't worked since 2013. I asked questions on here but never got an answer. Hopefully you can figure it out.
Oops, you mean lumbar. I did work on that too. Pretty easy to get to through the back of the seat.I repaired the gears in my drivers seat. Will see if I can dig up the info.
07-14 Tahoe, Yukon, Suburban Seat Gear Replacement
The adjustment gears for the rear portion of my drivers side lower cushion stripped on my 13 Suburban so I ordered the Gruven parts kit for it and finally got around to doing the job. There are plenty of videos out there so I won’t reinvent the wheel here but I thought I would share my...www.tahoeyukonforum.com
