[SOLVED] 2004 Tahoe overheating. New water pump, thermostat, radiator
S
stotzbotz
Basically the AC repair shop installed it years ago claiming it would help make the AC colder by not having hot water circulating through the heater coil. They cut the incoming heater hose and install it there. Turn it off or on depending on what time of year it is. Someone claimed that it wasn't a good idea with these vehicles so I'm going to keep it open for now.
Yeah, I'm old enough to remember. I saw them at Watkins Glen in the early 70's. 660,000 attendees.
NELLY1947
Hello and thanks in advance for any help you folks can give. My 2004 Tahoe with a 5.3 engine suddenly overheated today. Both the top and bottom hose felt bloated and full of pressure. Several months ago I installed a new radiator. 2 months ago I installed a new water pump and thermostat. Everything's been fine til today. On my way home after releasing pressure in the system by loosening the overflow tank cap which was also replaced recently, and adding some antifreeze I was able to make it home watching the temp gauge the whole time nearly max out then go back down some then repeat. Nearly 25 miles of driving suddenly the temp gauge goes back down to normal mid range for a few then climbs again. Appeared to me that the thermostat I was sold was defective so I went to the dealership and got an OEM one. After replacing it I drove just a couple of miles and it immediately maxed out the temp gauge overheating again. Hoses felt full and bloated again. There is no water in my oil and no leaks to be found. Wondering if the aftermarket water pump has a problem as it's a Murry brand from O'Reilly. It's not leaking or making any noises though. Just never seen anything like this and I'm so confused as to what to do next. Any help would be so very much appreciated. This Tahoe has been so reliable and a pleasure to drive and maintain.
Depending where you are just remove the T stat.If you are in the north where you need the engine to warm up for heat then you need one. Did you put the correct antifreeze / water mix in the new rad? Also if timing is off a bit that will cause over heating as will a transmission that is over heating.
RET423
Leave that heater hose valve open, you can't block them on an LS
The fan clutch should have resistance even when cold, if it spins freely when cold it's bad
When you top off the coolant, disconnect the steam port line at the throttle body as you fill to push all the air out, then reconnect it after you're full
rjdjbd
Sonoma County, CA
‘They are not very expensive at all. I like Autel and Foxwell.’
I have the Autel Professional OBD2 Scanner AL319 but purchased for another vehicle, simply to verify ‘ready’ mode for emissions testing in CA. I’ve never messed with it for any other purpose. How do I get temp readings while I drive: Live Data? Would have been a great visual feature with a recent ‘overheating issue’ on my motorhome with an 8.1L Workhorse engine.
Thank-you!
thatboy_eddie
Member Recommended
