Got my 2010 PPV
1BADI5
1BADI5
DMV
Well I bit the bullet and ordered the Atomic poly motor mounts and the B&M 70392 deep trans pan since I will doing the trans service and TruCool Max trans cooler next week.
1BADI5
1BADI5
DMV
What better thing to do when bored and have some black 3M vinyl in the garage. Wrap some shit fools.
1BADI5
1BADI5
DMV
I finished the vinyl work and now on to some paint.
Atomic motor mounts and B&M deep trans pan came in today.......and I got stickahs FTW; 10 more rwhp
1BADI5
1BADI5
DMV
Project name "Undercover Sleeper"
Completed (as of 27 APR 2020)
- Texas Speed Long tube headers - 1 3/4 primary/3" collectors
- Texas Speed 3" catless Y Pipe
- Magnaflow muffler 12259
- Rear resonator delete
- Ported LS7 Throttle body (ported by Me)
- Ported OEM intake manifold w/intake manifold gaskets & injector O-Rings (ported by me)
- AiRaid MIT intake tube / AEM dry filter (70k)
- Airbox mod (opened up inner fender and matched the Airbox)
- Cleaned the MAF (70k)
- HPTuners - work in progress
- Denso IR plugs / Taylor 10.4mm plug wires
- Gates HD Green belt, AC belt, idler pulley, auto tensioner
- Atomic Fab Performance solid motor mounts
- Holley powder coated valve covers (Tall) / new braided hoses & inline PCV
- UDR Catch can (black with black braided lines)
- AC Delco Professional 48 series Battery (3/20)
- Royal Purple HMX oil change (70k/75k)
- Royal Purple 75w90 Diff service
- Tru Cooler MAX - 40k Trans Cooler / with custom brackets
- B&M Deep Trans pan - extra 2qts with drain/temp sensor ports
- Trans service (OEM fluid/filter/gasket) (4/20, 75K)
- Replace both Trans cooler lines (AC Delco)
- StopTech SS lines (front/Rear)
- DOT3 Flush
- AC Delco PPV front rotors
- EBC YellowStuff front pads
- Rear pads
- Aerotech gauge with column pod
- Innovate Wideband (in, 4x4 headlight bezel)
- XTRONs HU with backup camera & forward facing camera & GPS
- OEM Remote Start added - RPO AP8, GM part 19154445
- OEM Auto Dimming rear view mirror
- OEM mirrors with signals/puddle light - *needs BCM update*
- OEM DIC install
- OEM Tow/Haul shifter
- OEM Steering wheel Stereo controls
- Grant Leather wrapped OEM wheel w/ fresh OEM spoke covers
- Husky mats - front/back/cargo
- New headlight housings w/ LED HI & Lows
- OEM foglights added - OEM switch/lights and wired
- LED light bar, LED tag bulbs, LED brake lights, LED Dome lights (red)
- BellTech 2/3 drop (spindles/springs)
- Yukon Gear&Axle (3.73 and Dura Grip) (Complete overhaul/rebuild @ 75k)
- Spohn adjustable Panhard bar
- AC Delco Professional front sway bar end links
- Goodyear Eagle Ultra Grip GW-3 - (265/60R17)
- Airhorn install 150+DB
- Dropped the spare tire out, deleted the spare hoist/holder, removed OEM bottle jack and tool kit, removed the spare battery tray, removed about 5 lbs of spare antenna cable from the rear of the truck, removed excess brackets and cabling from under dash
Next up - Ready to install
* OEM PPV shocks/struts & all hardware (ON HAND)
* ATI Harmonic Balancer (For Sale)
* Powerbond 25% under drive crank pulley/balancer (Ordered)
* ARP Crank bolt and new belts (Ordered)
* Light weight Alternator/PS pulleys
* Rocker Arm upgrade (either TSP or Terra Yella 1.7)
1BADI5
1BADI5
DMV
Parts ordered for a ring/pinion swap and Yukon Gear and axle Dura Grip positraction.
Going to 3.73 since 3.55 ratio was not available from Yukon Gear
Scheduled the install for next week.
1BADI5
1BADI5
DMV
are you replacing the whole axle or just the internals
New ring/pinion and locker; plus a complete rebuild (new bearings, races and gaskets)
So same axle housing and axles......but all of the guts are being replaced
Xay2Smoove
