Going to drop the tranny pan
1999hoe
aka HOVERHOE
Massachoochoosetts
And change some solenoids this weekend also gonna change the manifild pressure switch while im in there and obviously the filter and fluid ...what im curious of is there other easy maintainance i can do while im in there ......my issue is no overdrive
SnowDrifter
Sasquatch Country
Transmission filter while you're in there. Don't worry about replacing the seal that goes inside the tube
retiredsparky
If your repairs don't work to fix the OD, you could get a price from a local tranny shop to troubleshoot the OD clutch. They often know what it is without a tear down.
1999hoe
1999hoe
aka HOVERHOE
Massachoochoosetts
Well she needs to be feathered from 2nd to 3rd and has no 4th do you think its worth even messing with the solenoids ?
ZaZaZazzels
