Get a catch can before any mods.
St. Louis
So you gotta unscrew the whole bottom to drain it?
I'd drill and tap a hole and install a ball valve for draining
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
2001 Yukon SLT
Yes. I didn't want to blow my whole *** (and wallet) at once. Very happy with this for 25 bucks. And I still have tinkering upgrades I can make to it later. Add the drain ball valve, steel wool, better hoses.
Bruh... All you needed was to get this one:
https://www.amazon.com/Sporacingrts...=B07JQKHW9W&psc=1&refRID=K6RTT9T0Y2R1BVQ8K0TB
Already has the drain valve and a nifty shelf to hold the stainless scrubber pad. There may be some red versions of it for teh extra horseytorques.
89Suburban
SE PA
Yeah I missed that one. That mounting bracket looks a little flimsy though.
The bracket is a little thin. But, if you're not twisting on the body to remove the reservoir when draining (which is the convenience of the drain valve), it's sufficient.
donjetman
^^^I concur!
My brother is short, so I had to locate it closer to the front. It's in pretty much the exact same location as the catchcans.com one on my Tahoe.
Page 60, Post #595:
89Suburban
SE PA
Yeah I wanted mine up front where I can easily access it. I'll have to route the hoses a little different, they are in the way when I try to fill the washer fluid with the gallon jug. There must be a shortage of 3/8 hose. My local Pep Boys has been out for 2 weeks and I ordered a spool on Amazon and that is 2 weeks out as well. WTF.
Here is week #1 results: :confused:o_O
89Suburban
SE PA
Can somebody explain to me WHAT THE **** IS GOING ON HERE!!!??? :eek::eek::eek:o_Oo_O:confused:
1 week:
Week 2:
My brother stopped by yesterday and I was showing him this contraption. When we took the canister off and it was filled to the notch marks on the bottom, about a third full. 24 hours later I open it today and it is 3/4 full. WTF!!!!!!!! WHAT DO I DO!!! ????
Can I dump this back into the crank case? This is full ******* syntehic. $$$$$$$$$$
HiHoeSilver
Away!
Chicago
1 week:
Week 2:
View attachment 229355 View attachment 229356
Hmmm... never seen anything like that before. Thinking....
89Suburban
SE PA
Holy shit! Is it running the same? Is it smoking at all--through the tailpipe?
I used to get a smoke cloud on cold start but that's it, usually worse when it's colder out. Runs ok for a 300K+. Passes emissions, don't see any smoke when idling or driving down the road. I just don't understand how I get a little puddle in there in a week then week 2 it's almost full. WTF. Especially in 24 hours half a can, that is blowing my mind. Can I dump this back into the motor?
89Suburban
SE PA
I wouldn't. that is vapors and bad stuff. do you have the updated valve cover?
I didn't. I dumped it into a clear container and it was nasty ass dirty. So I disposed of it. As as far as I know this is all original. I could not find an updated VC for this model and year. 2007 5.3 Tahoe LT 4WD.
justinakay79
