donjetman
- Joined
- Oct 22, 2018
- Posts
- 2,011
- Reaction score
- 3,696
I have 3 that I've been afraid to attack for 6+ yrs. He makes it look easy.
I have 3 bridge clamps on mine too. I should leave well enough alone.I have clamps on 3 corners of the engine and no leaks/noises but when the time comes, I will prep for 2-3 weeks in advance with Aero Kroil on all the nuts/bolts.
The ones in my 2012 didn't have any thread locker on them from the factory. They all came out easily, thankfully.Did GM really use thread locker on steel bolts into an aluminum head or was he just kid’n?
I've been using the copper anti-seize on exhaust flanges (and exhaust manifolds to heads) for the last few years on my 06 Suburban.Would Anti-seize not help if the bolts were to be removed again or does it just burn off?
If anti seize had problems with heat, it would not have been recommended for years to be put on spark plug threads.I use anti seize on all exhaust stuff. I don't believe it's effected by high Temps.
I recently installed some Ti header studs on my ls3 car and I used a good amount. I am not drilling out Ti if I don't have to lol.
The grease that binds the metallic (or non-metallic) anti-friction components resists higher temps, and won't liquefy or flash off.I'm not sure if there's a difference between plain old anti-seize and high temp anti-seize, but the latter is labeled and marketed as such.
