Doors, paint, etc.
Mean_Green
Continuing from my punch list thread. If you don't want a bunch of threads on the same things, let me know. Boards are all different.
Neither front door will stand open. They both have the springs (found laying below caught by the lower fenders). I can re-locate the springs, but they just fall out again. Almost like another piece is missing.
As noted on the other thread, I need to find out how best to deal with the clear coat.
Mean_Green
Mean_Green
Is there a simple way to add turn signal indicators to the outer mirrors?
Mean_Green
Mean_Green
Am I building?
Or just fixing?
Passenger door handle is broken in one corner. Replacement ordered, but I need to figure out how to get the inner panel off. I've done it on several other vehicles, but I always break something and they never go back together quite right. Need to be more careful this time.
Mean_Green
Mean_Green
Door handle's replaced. Not a job I wanty to do again. Probabaly not as bad the second time, but when you don't know what needs to be done, it's as much discovery and figuring things out as doing.
Trying to get the inner door panel off was most of the problem ... just to get to one crummy screw.
Had the handle replaced and re-inserted, then tried the door. Didn't seem like it worked. Took me a while to figure out that these latches don't pop open like other brands. They just release internally and allow you to pull/push the door open.
east302
Mississippi
View attachment 395082View attachment 395083
The spring fits where your two arrows are pointing. The lever rests against the roller pin.
Compress the spring, set it in place and loosen the tool.
Mean_Green
Mean_Green
If you look at my picture again, you'll see that roller pin is missing. Just went out to check and it's gone from both sides. Not sure why or how to replace it/them.
east302
Mississippi
It’s GM part 12540326.
Dorman sells one that is “supposed” to fit but you have to grind down the beveled edge to make it fit. Like many dorman products, just skip the hassle and go with the GM part. It’ll fit just fine, I used one on my son’s truck not long ago. We’ve since sold that truck - else I’d grab you a picture of the new roller.
The top in peened from the factory, so the replacement will need to have a weld stitched on it to hold it in place. Otherwise, it will “walk” down over time. I didn’t try it, but you might be able to cut a thread on the top of it and put a nut on it.
Moderator
People's Republic of Colorado
If one could drill a small hole through the top end, would there be enough meat to put a washer on and cotter pin through?
EDIT: might be a hassle to drill a hole through such a small shaft.
east302
Mississippi
Good idea, anything is a better choice than welding it. One less thing to have to cut or grind off if it ever needs to be replaced.
Moderator
The other thought I would have is to cut a shallow "x" into the top with a hacksaw before installing it, then swaging it wide with a chisel after install.
Mean_Green
Mean_Green
That's probably going to be a Body Shop job. Driver's door sags and will need a pin and busing kit and I don't have any way to support the door. As you can see from the other items, I'll try most things if they're simple enough, but some are beyond my comfort level.
east302
Mississippi
Should you decide to tackle it, taking the door off was (to me) easier than trying to keep it balanced on a jack. Pull the plastic trim off the kick panel and the door wires have connectors there for this purpose.
Mean_Green
Mean_Green
If anything, I would support it from overhead with a hoist or similar. But I don't think I'll be trying this task.
JeffK
