Catch can fills up quickly
Donnyd21
I have a 2015 Yukon, 5.3, I installed a catch can and it fills up rather quick, about 1oz every 100 miles, that’s a lot of oil it would just burn if I didn’t have this installed. It that normal for these? The oil in it smells and looks just like that, oil, no hint of other contamination like water vapor. I’ve just been pouring it back into the oil. I will mention I have DoD turned OFF in my tune.
D
Donnyd21
I definitely have it hooked up correctly. I’m starting to think it’s normal with all the oil burning complaints on the Gen V’s.
STORMIN08
Apple to Oranges comparison.
really ?
other than a possibility of high compression ratios, the rings allowing that much oil to pass is unacceptable. the shear lack of firing the cylinder is allowing excessive amounts of oils to hang on the walls. where as a fired cylinder seating the ring aids greatly in scraping oil back down below the rings.
Captain Insaino
sacramento/placer county, ca
My LS1 Camaro only puked into the can on high RPM accelleration/decellerations. I don't know a lot about these trucks, but is your PCV valve stuck open? Do you have a high idle? Something causing high block pressure? How many miles?
ivin74
05 NBS Nali
Htown, Texas
How many miles are on your rig?
X2
D
Donnyd21
113k miles. Removing the oil fill cap during idle shows no excessive crankcase pressure. Normal idle rpm.the PCV is integrated into the valley cover, no idea how to check if it’s stuck open on these
ivin74
05 NBS Nali
Htown, Texas
The PCV valve is not integrated into the valley cover, please see attached diagram. Please change it out and report back.
ivin74
05 NBS Nali
Htown, Texas
You can also add a fuel filter after the pcv valve an see how much oil it collects on it. I added one on my 6.0 and you will be amazed how much oil still goes thru the catch can.
Abuilyas
Mostly it is the valve cover that comes on it, the one you buy (OEM) comes with the lip rather than a hole and it makes huge difference with the oil loss if I may say.
ReedR
Since you have disabled
Since the DoD is turned off it's possible that the high
Since you have disabled DoD it's possible that the high volume oil pump is to much and is pushing the extra oil into the valve cover continuously and out the pcv valve. Specially since the oil is clean.
Tiredmechanic23
PCV valve is not in the valve cover on these engines. It is under the bottom corner of the throttle body. The 2 valve cover hookups are just breathers. They do not connect to a catch can. Though you could connect a clean side separator to them.
HACK BLOCK
NYC
post a picture of how u have it set up. since it's been said the pcv isn't a part of the valve cover then you most likely have it wrong
D
Donnyd21
New PCV installed, 225 miles later still getting quite a bit in the can:
6point2lovelifers
