Any & all help/suggestions welcome
NoReverseYukon
NE Wisconsin
For the "scrubbing" sound, while you are driving when/where you can hear it, apply the brakes lightly and listen for the noise to stop. Otherwise, as Luie mentioned, it might be wheel bearings.
Jeremy4601
Jeremy4601
Semmes, AL
The front suspension is torsion bar style, so no coil springs, and likely that's not been changed unless the keys have been cranked (front end "leveled"). Your jounce stops -- the front ones are not "bump" stops -- play an integral role in the handling and act as a fulcrum point of the suspension. They should be in good shape and, at ride height, be contacting the lower control arm right near the shock. This shows you where they are:
Absolutely check all of the front swaybar links/connections for tightness, and make sure the bushings are in good shape. They're not expensive and do end up deteriorating over the miles and years.
After checking the easy stuff on the front end, I'd probably concentrate on the rear suspension first, since replacing the OE shocks with standard ones is known to make the handling bad. I think that the front OE shocks for the Premium Smooth Ride are smaller Nivomats but I could be wrong. I think just a good heavy duty shock up there would work fine, and yours might be okay after the rear end work. Maybe someone with more experience on the fronts could chime in.
Great points on the front end stuff. Sway bar links and jounce stops look pretty easy and inexpensive so I will likely go ahead and replace them. May as well.
Regarding the front shocks I found this:
3B2EEA83-D88D-4D86-A812-4343BD15A239.jpegSeems to indicate that the Nivomats are just on the rear. Still thinking I will go ahead and put some better ones on the front anyway.
Had another thought on the rear. What if I try to find some OE Nivomats in a parts yard and just kinda go back to stock and see how it rides? Of course that will depend on what they want for them, considering they will likely have miles on them. Any idea on lifespan of these stock shocks?
The Nivomats on the rear of my '04 are at 105K and still work properly. I think someone here had a used set for sale @BADRIDES?
You can test the auto adjust feature by loading up several hundred pounds of whatever in the back, measuring the (low) height before driving a few blocks. The shocks should raise up the back end to normal ride height within a block or two.
Jeremy4601
Jeremy4601
Semmes, AL
After a lot of back and forth, I have decided to go with the Bilstein 4600’s all the way around and the new springs on the rear. I don’t do a lot of heavy lifting with my ‘hoe so for all the trouble, I think I’d rather go ahead and start fresh. I also ordered those new jounce stops and sway bar links. After this coming weekend she ought to be riding pretty damn good.
I appreciate all the info, advice and input. I’m sure I’ll be posting a new question soon enough. Lol. Lots of plans for my rig. Thanks a ton.
Great, sounds like a plan. Let us know how it goes!
BG1988
It seems I may have really stepped in it when I changed those shocks. Not knowing any better, I trashed the OE shocks. I guess I was just throwing mud at the wall and hoping some of it would stick. Just look at me now! Lol
Those Nivomat shocks look to be $300-$400 a piece.
BBC
ACDELCO 540433 {#25871225} GM Original Equipment Info
Rear; Premium Smooth Ride Chassis Pkg(ZW7) 5.3l
$54.79 $0.00 $54.79
To be clear, G65 is the RPO code for the manual self-adjusting Nivomats, found on the Premium Smooth Ride suspension:
BG1988
bill1013
Waianae, Hawaii
The front sway bar effects the steering immensely. My 1999 Tahoe (4X4) front sway bar bushing was worn, then fell out, and I damn near lost it onto the median. It was scary, but what made it worse was the wife & kids were in the truck. I was cruising around 60 on the highway and I had to make a quick lane adjustment to avoid debris in the road. Next thing I know I'm all over the road. The bushing must have been worn and the quick jerk on the wheel made it come out, thus making the bar a mute point. By all means...check the sway bar bushing. Also, if you feel like you're steering a boat on rough seas...check the bushing, it's probably worn.
Javie
Burbank Ca.
So, I have been working through a few “ride” issues with my Tahoe for some time now. I am down to just a couple things that I can’t seem to satisfy on my own. My two remaining problems as of now are:
1. While driving I am noticing a “scrubbing” noise from the truck. It sounds like a sanding block being worked back and forth. I can only hear it when my window is down and I pass alongside other vehicles or fence lines allowing the sound to be redirected back at me. I assume it’s something to do with either axle on the drivers side, but I have been thru both and not noticed anything jumping out at me. That isn’t saying much tho as my mechanical knowledge is... well, let’s just call it “limited”.
2. Much to my dismay and despite my best efforts, my rig tends to “float” down the road. The steering is tight, it takes bumps pretty well, and I have done quite a bit of work to correct this (list of such is coming up next). I have made significant progress, however I still find myself working harder than I should have to to keep this thing between the lines.
In the past few months I have replaced brake pads, rotors, and calipers all the way around. I replaced the steering gearbox, pitman arm, and idler arm. I had the front end aligned. Also have had two different shops go thru the front end and have been given a clean bill of health from both.
I also replaced all four struts. Not knowing much about these, I went to O’Reilly’s and bought what they said would fit. I tried to look back to be able to say exactly what I put on there but I was not able to find that info. I definitely did not spend more than $50 on each, so I may have gotten exactly what I paid for. The struts I took off looked about the same size as what I was putting back on so I had no reason to question anything. They also appeared to be OE as they definitely looked like they had been on there for a long long time.
I am running aftermarket wheels. Ballistic 20’s along with 275/55/20 tires.
Sorry for the long-winded post, but I’m struggling to sort this out on my own... so I wanted to be thorough with my info. I’ve just turned 240k on the odometer, so I certainly don’t expect her to ride like a brand new truck. But it’s gotta be able to get better than it is. Any thoughts, experiences, or suggestions would be greatly appreciated.
OK so i am late to the party here and you probably already got the answer you needed but i am gonna give you my 2 cents anyway. You see I had the exact same problem you are describing as far as the "floating feeling" you get from driving around . I use to get it especially bad on the highway felt i would be getting pulled over for suspicion of dui!! Lol ! Anyway long story short i purchased an aftermarket rear sway bar from eibach and paired it off with energy suspension polyurethane sway bar bushing links and problem solved. Now my hoe hugs them street corners better and more aggressively than a $20hooker on Saturday night!
agmanw8n
