And always remove the fill plug first. You don't want to have it drained, just to realize you can't fill it 'cause the fill plug is frozen.
"Old" and "vintage" together is somewhat redundant, but I get your point. Simpler vehicle for a simpler guy. I resemble that!![]()
Got it. Any recommendations on what brand/type of gear oil to fill it up with?And always remove the fill plug first. You don't want to have it drained, just to realize you can't fill it 'cause the fill plug is frozen.
Here’s what your manual says:Got it. Any recommendations on what brand/type of gear oil to fill it up with?
So having some trouble getting the harmonic balancer fully seated. Couldn't get it all the way on with the installer so I tried putting the ARP bolt on and cranking it with a breaker bar. No go. Now the ARP bolt doesn't want to come out. Think I should hit it with an impact?
I agree. I'm gonna remove it with an impact and try the installer again. My biggest fear of this entire job is stripping the crankshaft...to remove the bolt, it's probably fine. I zipped my original one off with impact. but I wouldn't try to seat it with it. something isn't right, mine wasn't hard to go on at all. I did use anti seize on the inner hub thou. didn't call for it, but I did anyways.
might see if you can remove it, check for any scarring, clean it up. lube it and try again. I believe the manual says to seat it fully by tq the old bolt to a spec. I don't remember what that is right now, but I wouldn't go byond that number to seat it.
Got it seated with the old bolt. Tha ks for info!to remove the bolt, it's probably fine. I zipped my original one off with impact. but I wouldn't try to seat it with it. something isn't right, mine wasn't hard to go on at all. I did use anti seize on the inner hub thou. didn't call for it, but I did anyways.
So getting ready to drop the lifters in and wanted to ask a few questions. #1 is to clean the ports thoroughly. I'm going to use a rag sprayed with some brake kleen and wipe upwards best I can to prevent any dirt from falling down into the motor. They're already pretty clean. Then drop in lifters first then trays? From what I've read the trays will prevent me from putting them in incorrectly because the flat side lock into the trays. And got to make sure the roller is sitting on the cam properly.
Also doesn't matter which way the oil hole is facing?
Last I cant believe the debate everywhere I look over wether or not they should be soaked! I soaked mine so at this point it doesn't matter but some serious online fighting going on over this!! I was hoping to do this today but supposed to rain all day in N.J. so might have to wait.
