2008 Tahoe Engine Swap (2008 LMG to 2013 LC9)
Coolman1987us
Coolman1987us
Maine
Ya I'm good with the 4 speed, I don't tow enough anymore anyway.
I'm thinking about keeping the vvt since it's so easy to keep. Probably going to splurge for the hptuners mpvi setup or whatever that is , more toys to play with.
Turbo? Now why did you have to go and mention a turbo? Maybe an lmg rebuild is in the future :p
Any idea what transfer case it would be? and what the pair are worth?
You'll have to google around for local market prices in your area. In Florida, they go for between $300-500 around that mileage. The transfer case is an MP3023 if it's an automatic with 2-speeds. If the Sierra has a single speed automatic transfer case, it's an MP3010. If it is a manually activated transfer case, it's an... gee I forget! LOL MP16XX or something like that. If you give the Sierra's "N" codes from the RPO sheet on the glovebox door I can look it up.
Mission Creep! Careful, before you know it that LC9 will have Darton wet sleeves with 4.125 pistons and a 4 inch crankshaft and 2 turbochargers on it!
Coolman1987us
Coolman1987us
Maine
Lol my pockets aren't that deep.
It's the 2 speed with auto 4wd, electronic shift so that would make it the 3023, thanks.
Coolman1987us
Coolman1987us
Maine
So after reading a bunch and getting real familiar with the afm system I'm wondering if a full delete is really necessary. If I shut the afm in the ECM and pull the valley cover and plug the oil passages, the only real problem that remains would be if a lifter spring were to break causing the lifter to go limp, correct? From what I've read a broken lifter spring is rare? I'm wondering if it's really worth the 1000 dollars to replace everything or just shut it off. I wasn't really planning on spending $500 just for HP Tuners, and another 200 for a clone Tech II, that's over a quarter of my budget. Shit gets deep quick lol.
Dustin Jackson
@Coolman1987us There are other ways that the lifters can fail. Heck my lifter failed 6 months AFTER I tuned AFM off, while I was cruising to Target. It looks like the lifter turned sideways in in the lifter tray which is another common way that these fail. Lifter springs breaking isn't how the lifters fail there may be a misunderstanding about that.
I say you can start with a tune-delete now if you want and then do the hardware delete later down the road if needed.
Coolman1987us
Coolman1987us
Maine
It's going to be way easier to do it while the engine is out, I'll stop being cheap now lol. I'm going to start with a Texas speed kit I guess. Found one for $700 but not sure what it includes. I guess I'll start a parts list right now.
Coolman1987us
Coolman1987us
Maine
Well I learned something new today. The mileage is stored in the cluster not the ECM, who woulda thunk it. I figured the ECM would store it so you couldn't change the cluster and reset the mileage. Makes me wonder if my Tahoe has 199k or if its really more.....
Edit: this is the '13 sierra cluster
Coolman1987us
Coolman1987us
Maine
She's free! Scored harbor freight engine stand on sale for 80 bucks.
Coolman1987us
Coolman1987us
Maine
Had to make 2 posts for all the pictures
Coolman1987us
Coolman1987us
Maine
Between that and the Tech2, you can diagnose, do and undo just about anything the factory did and then some. I feel I'm still on "Page 1" with HPT.
Oh ya I'm still on page one with hpt also. Figured out the standalone data logging and just been taking logs until I have time to sit down and go through the software. I was skeptical when I bought it but it's definitely worth the $400 especially that the pro features are now built into the mpvi3. Looking for a wideband now.
mikez71
Yep, there's a lot of settings and many I have no idea what they do.
(I think some settings aren't complete or may not apply)
What I have done:
disable afm (of course, way better that way)
set cooling fans to come on a little sooner
set power enrichment delay to 0
turned off ETC and spark for the traction control.. haven't tested
disabled speed limiter?.. haven't tested
shift tables are great (6l80), holding in a gear a little longer and downshifting a little sooner definitely helps.
might change my alternator voltage..
probably not going to mess with shift speeds and tcc pressures..
Plan to dial in shift/tcc tables, but it's a definite improvement as is.
What else have you all done/are planning to do?
Coolman1987us
Coolman1987us
Maine
That's a good list, I'm gonna steal it, I was also thinking of bumping the entire charge table up a half a volt or so. You figure out how to do that cause I haven't yet.
brice715
