07Burb's Exhaust Thread
soulsea
Bar
Looks good Jacob.
If I may ask ... in the 'before' vid there's no smoke/exhaust coming out of the pipe, in the 'after' vid there seems to be a lot, do you know why? :think:
It's probably because when I did the first vid the burb was stone cold. For the second vid there was most likely condensation in the pipes that was getting blown out. Know what I mean? Also, when cutting the resonator off I used a grinder and cut off wheel. Not sure what that heat and will do with regards to also build up condensation.
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Thats perfect. Any smaller of a muffler and your going to get a lot of drone. Keep in mind, it will get a tad louder because the muffler hasnt broken in yet.
soulsea
Bar
Kewl, as long as it went away after a while ... resonators should have no effect on emissions anyway. :waytogo: Congrats, truck's looking hot!
Btw ... WERE those the new neighbors or not? The suspense is killing me. :)
No doubt sumo! :) looking forward to it breaking in all the way. It's already gotten louder after the 1000 mile road trip last weekend :)
what new neighbors, soulsea?? :)
2005yukonxl
arent the tips a tad close to the body panel? id be afraid of movement causing them to make contact...but looks great.
I was worried about that too but they aren't going anywhere. It's pretty tight with just enough give not to cause any damage. Also, that panel above that is very flexible so breaking or cracking would be very unlikely :)
---------- Post added at 09:49 PM ---------- Previous post was at 09:47 PM ----------
Haha!!! We'd just come over from across the street looking at baby rabbits in my neighbors yard. We don't talk to them much so he considers them 'new':)
2005yukonxl
sounds alot like ours does...i'll make a video one of these days if the wife brings the thing back home and lets it sit here long enough for me to do it...
Vincesrg03
Illinois
Lookin good Burb. Was wondering if the magnaflow and tips were an urban legend with you.:shocked: lol. Nice to see you got it in. Any pics of how it looks underneath by the muffler? How much smaller is it than stock? Is that resonator only on the nnbs suvs. Mine doesnt have one. Thinking about just adding a tip.:mexsmoke:
:lol: I don't have any pics ofthe muffler right now but I can definitely get one for you. I'll try and do that tonight. The resonator is only on the nnbs burbs (and oter various vehicles) but not on the nbs rigs. :waytogo:
I'll get you that pic as soon as I can. Overall the body of the muffler is slightly shorter than stock.
I tweaked the tips a bit more tonight to get it a bit further away from the plastic. Can someone with these tips or similar tips compare this to theirs and see if there's is about the same? I'm paranoid about it gettin too hot foe that plastic.
also, I forgot to take a pic of the muffler but I will and it posted up later on.
jd08
Jackson, WI
my tips are about the same distance away. I think I can fit my fingers in between, maybe .75-1" clearance. Had it this way for a couple monthes with no problems
felixgun
Lafayette, LA
Looks good Jacob! My volant super tips is a one piece all welded together. I didn't realize the slp tip was two separate bolt on pieces. You did a great job installing it!
Thanks! :High 5: Yeah, I kinda like the multiple pieces for the purpose of installing it yourself cuz it's make it easier to adjust and tweak it just right. Eventually I may weld the assembly on but for right now it's on there with the supplied clamps and you can put them on there in a way to where no one sees them so that's nice too. The hardest part was getting the resonator off cuz it's hard to get up there with enough room to cut the pipe and make sure you don't cut on anything else (i.e. brake line :eek:). So you gotta really pay attention when you're doing it :)
felixgun
Lafayette, LA
Yea I'm not a big fan of bolt on when welding is an option. I had the a local muffler shop cut the resonator/stock tip off and weld on the tips because I do not plan on ever going back to stock. :Handshake:
no doubt! :Handshake: I'll never go back to stock either. It'll be welded shortly but just wanted to get it exactly how I wanted it first before making it permanent :) Stock is definitely NOT for me in this area of modding :D
felixgun
Lafayette, LA
Yea I agree!
soulsea
Bar
Burb, is that a stainless steel tip?
I've been told you can't weld ss to whatever metal the tailpipe is made of. :think:
protonvx
I am not a wleder; but, I do employ welders. They can weld almost metals together with the right rod and the right settings on the welder. I know they have welded stainless to mild steel numerous times for me.
JeffK
