Suspension Maxx suburban 2020
Subanbur
Hello
I recently purchased a the suspension Maxx leveling kit. I followed instruction procedure. I disconnected the upper arm ball joint and lower ball joint for extra slack . I used a 5 feet pipe pry bar and couldn’t even insert the 1.5 spacer. I wonder what I’m doing wrong?
STORMIN08
your sig say TRAIL PACKAGE ??? is it a Z71 ? it may have a setup that already has an adjusted height.
Subanbur
Subanbur
No it’s not the z71, it’s basically the z85 suspension with autotrac 2 speed
I watched numerous videos on Silverado's pick up who share the same frame and all of them disconnect the outer tie rod which I didn’t do. Looks a bit easier. I’ll try again. I’m only lifting the front for now 2.5 and I’ll lift the back 1.5 with the shock extension for the air suspension. I’ll take pics during the installation.
P.s In the suspension Maxx installation video I noticed that he didn’t do the 2.5 lift I think 1.75 inch and there’s a gap better the before and after installation of the 1.5 spacer.
here’s a pic of the option on the window sticker, sorry for the FRENCH!
Subanbur
Subanbur
Ok I finally managed to install the suspension max 2.5 front leveling. Let me tell you, no way in HELL would anyone be able to install that by themselves ALONE. NO WAY! It was hell trying to pry down the upper ball joint but me and buddy (both mechanics) managed to do it. I wanted to take picks but time wasn’t on our side as the dealership was closing at 8 p.m for some odd reason. Now I’m going to level out the rear with the 1.5 spacer with shock retention from suspensionmaxx. I’ll bring in the shop tomorrow to do a alignment.
Subanbur
Subanbur
So I ordered the 1.5 inch spacer with the 1.5 shock extension. Going to install that on Friday and post some pics
STORMIN08
in for the pics...really debating level/lifting the wifes 17, i would like to see front ball joint angles if possible.
just level ground and wheels can be turned.
Subanbur
Subanbur
I’m going to install my rear spacer (1.5) with the shock extension tomorrow. I’ll take pics of the front ball joint
Subanbur
Subanbur
Here’s the complete 2.5 inch front, 1.5 rear spacer set up with 1.5 shock extension.
7C36EC94-0525-4AFC-B51F-1FD4D67E9D94.jpeg BDE4590A-C56B-4849-A73E-28422CBE26C1.jpeg
I took pics of the ball joint but it’s on my other tablet. I’ll upload it tomorrow. Now I need to do a alignment.
I did a small half hour road test. Everything is fine, rides just like stock.
STORMIN08
thank you...the height is what i am looking for, but this does indeed tell ME, that i want replacement upper arms.
i do recall on my 2011 Tahoe, after level and alignment, the steering feel was slightly tarty until i did upper arms.
jmart157
