the_tool_man
Upstate South Carolina
5strmtrp
Make sure to get the ones for Mini ATC fuses, NOT Mini ATM.
Also, to install it correctly, the fuse you pulled from the fuse box goes into the bottom connector and the newly added circuit fuse (3a in this case) goes in the top connector
Can you elaborate on the the different fuses? ATM vs ATC? Looking on Amazon some say the difference while others are vague as usual. Overseas stuff
St. Louis
The size fuses that are in our fuse boxes are ATM. ATC are larger and usually used in older vehicles.
rick3645
