Monz11
Da Burg, Fl
Finally installed Eibach front and rear swaybars with Moog stabilizer bar link kit!
Got started on installing new stainless braided wire loom, this is a pain in the A$$...but will be happy when its completed
08grey
Chert_Detective
Picked up my tires today. Stock size 275/55/20 Toyo Peoxes S/T. I had been looking at Nitto 420S 420V and 421Q but these were on clearance, $140/ea for a $220 tire. Hah!!
I don’t think I’ve posted a booty picView attachment 251531
That fitment is on point!!! :worship::worship:
What lights are those? I have been thinking of tinting some oem Escalades and getting the upper piece or some decent led aftermarket ones.
1BADI5
DMV
Thanks, I was just trying to help. Since my PPV did not have anything for foglights (switch, harness, lights or BCM programming) I had to get clever w/o making it difficult.
Knowing I was going to use LED bulbs made it easy since there would not be much voltage or amperage being pulled. I think I posted this up in my build thread
Just glad I was the easy button for your fix
the_tool_man
Upstate South Carolina
5strmtrp
Make sure to get the ones for Mini ATC fuses, NOT Mini ATM.
Also, to install it correctly, the fuse you pulled from the fuse box goes into the bottom connector and the newly added circuit fuse (3a in this case) goes in the top connector
Can you elaborate on the the different fuses? ATM vs ATC? Looking on Amazon some say the difference while others are vague as usual. Overseas stuff
St. Louis
The size fuses that are in our fuse boxes are ATM. ATC are larger and usually used in older vehicles.
ATM on left, ATC on right
