Confused about lowering
NORCAL SS
SUV SUSPENSION GURU
No. If stock links are in there the compressor would kick on to try to keep the rear up. Like I said light on dash won't go away. Those linkages won't do it.
GO to store
Get 10x 24 machine screw
Cut ton2.75 inches long
Replace oem rod in rear
Turn on truck and sign will still be on dash and air compressor will not function correctly. Im.just trying to help you resolve this issue asap.
By removing the front shocks the system will stay in fault
popo8
popo8
Ok... i have ur number (thanku) and when Im at the truck again ill reach out to u.
LTXtech.com IS my drug...
---------- Post added at 07:24 AM ---------- Previous post was at 07:20 AM ----------
Called and spoke to belltech and we missed the shorter rods. So they are on their way.
They also confirmed that the kit was made with the intentions of the drop to keep the air ride system in tact.
The nitro shocks which they had suggested are also made for the 02 caddy as a factory replacement. Although i did not climb under the front, ive been assured that they plug in or attach or connect (whatever the proper term is) to the factory stuff, in order for the truck to see them as it did with the factory stuff.
just wanted to post this public for future learning experience for others.
Sounds like the shop you used is sticking by and helping out to make sure you're happy :waytogo: That's good to hear.
popo8
popo8
Oh yeah. They are a great bunch of guys. Thats why i have no problem with the learning. Its not like anything was destroyed, just missed some steps.
Yeah, I agree. Great customer service can make up for some short comings in situations like this :) ...and in the end you'll be happy and all will be great. Coming along nicely.
popo8
popo8
Im in love with the look already. All of the cosmetics are a1.
Soon as the light is out cause everything is functioning properly, i need to hook it up to a loaded trailer and see how it tows lowered.
NORCAL SS
SUV SUSPENSION GURU
Just seeing if you got light off dash? Also airlift 60742 ie needed if towing. It just helps take off pressure from the oem air shocks in rear.
---------- Post added at 04:39 PM ---------- Previous post was at 04:34 PM ----------
No not correct. Belltech never made a shock to plug oem system into on any of their front shocks on autoride. It's a replacement shock but does not keep autoride working. You will need to Splice in resistors to get it to work right. Then autoride will work and no more lights on dash.
If your towing for sure get airlift 60742 helper bags. They are perfect and even improve ride quality when no load is on the truck. I did a how to thread few weeks ago of me installing them on a tahoe which shows it all
popo8
popo8
Waiting for those shorter rods to come in.
NORCAL SS
SUV SUSPENSION GURU
When they don't just give me a holler I have the resistors. Just did a 06 esky yesterday guy put in Gabriel shocks in front and autoride stopped working. Spliced in resistors and light turned off and his autoride works now
popo8
popo8
U got a deal. Have ur number saved.
---------- Post added at 08:54 PM ---------- Previous post was at 08:53 PM ----------
However if i dont trailer, its ok tondrive it without that air thing working?
NORCAL SS
SUV SUSPENSION GURU
Your rear shocks are dead even valving inside that regulates shock pressure not working because front system is not hooked up. Your best bet is to get autoride system to work since shocks are on there.
The links they are sending won't fix anything
popo8
popo8
But u said previously that they are there for trailering. So my question is, is it ok to drive with them non operational if im not trailering?
NORCAL SS
SUV SUSPENSION GURU
You can do it but the valving of the shocks is totally dead. It's a 10 minute fix Splice in connectors and autoride works and light is off and set to go.
I would make sure autoride works. Better handling and load control and no more light on dash.
popo8
popo8
Ok. Ill need to look up where the splice goes in & u said u have the resistors..?
popo8
popo8
Norcal, is this the spot on the front shocks where ur saying the system would plug in to the stock shocks so that it works right?
---------- Post added at 04:24 PM ---------- Previous post was at 04:24 PM ----------
NORCAL SS
SUV SUSPENSION GURU
Front is different fitting. Open hood you will see harness laying there above shocks
popo this is the front connector for the autoride. The module attached to it is the Arnott bypass resistor which I removed and replaced with 3.9 ohm 25 watt wirewound resistors soldered into the wires. The Arnotts kept failing. The connectors should have attached to the tops of your stock shocks. They're probably tied away somewhere now.
NORCAL SS
SUV SUSPENSION GURU
also the ones on ebay if you dont have radio shack by you. radio shack here closed
popo8
popo8
Thanku guys.
Just found that the compressor is seized. Lol. Like i wasnt having a hard enough time learning without the added complication.
That sucks. Arnott sells replacement compressors with lifetime warranty. As far as the resistors, yes I got them off EBay. I'm glad I fixed my autoride. I can ride lowered and when I hook up my trailer it adds air and doesn't bottom out, still rides great.
Conedaddy
