Confused about lowering
If I remember that's right, 2/3. I can't get the rear any lower although I'd like it to sit level. I experimented with different length links for the autoride and if I make them any shorter they pop out when I jack up the truck to pull a wheel. NORCAL SS do you have a solution for this? I'm actually thinking the shop might not have installed the shock extenders. That would make a difference wouldn't it?
NORCAL SS
SUV SUSPENSION GURU
Yes no shock extenders makes a difference along with pushing the shock shaft way far in
Tony I sent you an email, hope we can get the rear of mine lowered a bit more.
popo8
popo8
I like the rake
LTXtech.com IS my drug...
---------- Post added at 06:01 AM ---------- Previous post was at 06:01 AM ----------
Yes was messaging with him as well. He has good info poted in this thread from earlier.
I ordered some DJM endlinks and bumpstops from Tony. Looks like I'll be cutting the factory bumpstops off for the free travel mod. That looks like fun. Good thing I'm a ninja with a sawzall like some others are. Then hopefully I can make some shorter ride height sensor rods to get it down a bit more.
popo8
popo8
Well my appologies to norcal. I thought my guy was gonna talk to him and buy from him after i set it all up for them to talk... but i never followed up. Just assumed he did. Truck is being lowered now... and i told em that it looked like the kit from norcal was good... he said he got it somewhere else.
Im sorry. I shouldve paid more attention man.
NORCAL SS
SUV SUSPENSION GURU
No prob.. no one else has my springs since I'm the one that designed them
---------- Post added at 03:47 PM ---------- Previous post was at 03:45 PM ----------
Thats if you did my 3/5-6 kit
Looking forward to pics and seeing what shop actually set up for you.
popo8
popo8
Thanku. I feel horrible.
08grey
@NorCalss Tony if you ever have a set of oem escalade front springs you can sell let me know. I changed mine to ltz and they sit high even with the drop.
NORCAL SS
SUV SUSPENSION GURU
Send me your struts Ill mill them down like on my escalade. 3 years NO issues on mine
popo8
popo8
Well here is one picture...
NORCAL SS
SUV SUSPENSION GURU
What kit did they use?? should sit lower which i can help you tweek it in.
Did they use shock extenders/cut bracket off frame/endlinks and new bumpstops on axle?
popo8
popo8
Idk... remember what i wrote above.
---------- Post added at 12:15 AM ---------- Previous post was at 12:15 AM ----------
Its 3" down in that pic.
NORCAL SS
SUV SUSPENSION GURU
What parts did they quote you for on bill? belltech? endlinks also?
popo8
popo8
Ill quote what i wrote earlier as it shows i dont know...
---------- Post added at 12:24 AM ---------- Previous post was at 12:23 AM ----------
I dont have a bill to tell u whats quoted.
popo8
popo8
Its just shy of 4" lower in the rear.
popo8
popo8
Im not at the car... its still at the shop. Along with my incomplete invoice and list of parts used.
---------- Post added at 05:21 PM ---------- Previous post was at 05:15 PM ----------
Im not sure what u want to prove... u wanna prove that the kit is not as good as urs... maybe it is... maybe it isnt... idk... in fact at this point it does not really matter does it.
Fact is... the truck is lowered... im told it drives well... it will be going for alignment next week... then when some other work is done ill pick it up...
Then i can take all the pics u want so u can tear apart whatever u want...
Noooo im not getting defensive.... but i have had enough of ur small comments like... "ummmm..." and all following up ur... aknowledment of my appology that i thought ur items were purchased.
I keep failing to read that the truck was in the shop still, and every response of urs has been of u "barking" some type of order to u... what was used... take a picture of that... whats on ur invoice.
I think what u meant to say was probably the more professional. "Hey man... as long as ur happy..." but no... ur THAT GUY... U KNOW...That guy that needs to question or point thinga out to try... TRY to point out that ir stuff is better (whether it is or isnt."
Yes... ive clearly had enough and ill be happy to post up pics for u to do whatever ud like with it...WHEN I HAVE IT BACK!
HeavyHoe03
