Get a catch can before any mods.
HoS
So, catchcan.com is a woman's purse website... Not what I am into...
Oilcatchcan.com? But it redirects to a different site.
chevync
North Carolina
I got mine in monday, hoping to have the tahoe back by wednesday or thursday so I can install it. I haven't driven it in over 2 months. lol
NGAneer
NWGA
After 4000+ miles from my Home Depot catch can.
dub02gpgt
dub
WI
Not to beat the obviously dead horse, but if oil consumption is one the the problems you're having would you be any better off considering the valve cover replacement? Or is this in addition to that "fix"?
CHOO CHOO
BackPagePhil
Manheim, Pa
I have been with the understanding that this is very common among gm vehicles even at brand new or very low miles.
---------- Post added at 03:48 AM ---------- Previous post was at 03:45 AM ----------
17k miles on a brand new esky. Should not need anything fixed this soon, this is just normal
NGAneer
NWGA
My understanding as well. Lower tension rings, blow by when in V4, etc. Basically GM trying to pull out all the stops to squeeze more mileage from a 10 year old engine design (in my case). The consumption goes away, as I understand, when you tune out the AFM.
al2fast
Wisky
Put on my airaid intake tube and took a picture of the crap in my intake of my 09 Yukon Denali 6.2. Tips for cleaning? Already installed a catch can, my first mod! There is some smoke in there so hard to see it all with my crappy cell pic, but oil on the bottom with some tan **** bomb on top.
justinesky
I was wondering this as well but i can not find anything about this anywhere.
RotaryMachineRx
Saskatoon, SK
So I popped my engine cover off and had a look at installing this catch can. Before I do so I have a quick question. The existing stock hose running from the back of the valve cover to the top of the manifold is a hard black plastic and seems to be smaller diameter hose than the stuff provided with the catch can (maybe the ID is the same but OD is definitely smaller).
My question for you guys who have installed this, did you just pull this harder stock hose off of the fittings on the manifold and valve cover and fit the new hose directly to this fittings or did you have to replace the fittings themselves too? I was pulling on the hose on top of the manifold in attempts to wiggle it off but I felt like if I pulled to hard I was going to break the plastic fitting connected to the manifold and really be hooped. Any comments or suggestions? Do I just pull the stock hose off from these two fittings and slide the new hose on in their place?
CHOO CHOO
BackPagePhil
Manheim, Pa
I Just used the stock fittings. Shouldn't be that hard that you would break fittings
---------- Post added at 10:52 AM ---------- Previous post was at 10:51 AM ----------
You didnt twist the fitting did you? It should twist off if i recall correctly.
---------- Post added at 10:55 AM ---------- Previous post was at 10:52 AM ----------
RotaryMachineRx
Saskatoon, SK
Yeah I didn't get overzealous with it, just took a quick glance at it and fumbled around with it.... I'll try prying the hose off; don't think there should be any need to remove the fitting itself if not required.
Yuko04
"SquareBODluvr"
MN
My trip to Kansas and Missouri.
1400 miles and just emptied this yummy slop.....
Jiggy-J
cdhpc2
