Get a catch can before any mods.
BigBlueLB756
By Marion, MS
Paint to suit, if you like:
jdpber
GOLD MEMBER
The America
Just never thought of using an air compressor water/oil separator.
John is all about bling
jdpber
GOLD MEMBER
The America
I bought one to do it this way from Sears...... I actually ended up using it as its intended purpose and put it on my compressor
lol
I have a $300 paint gun specific oil separator and a 2nd stage air dryer. I mean to tell you they are the bomb diggity in the shop when painting. Bypass the dryer for the air tools.
As far as the engine in truck. I probably should add one. I clean the TB and intake once a month. But that shit has gotten old.
shundal
NorCal
Been running the Sears setup for about 8 months. It's been doing its job and catching quite a bit of oil.
TheAutumnWind
I need to get around to doing this mod.
It looks like oil/water separators are an acceptable low budget replacement (i don't need no blingy billet can), which is good because I may have one laying around...
HUMBL57
AC Guru
Phoenix, AZ
heads up i changed a guys unit with the catchcans.com one and in 3k miles picked up double the amount. not all catchcans pick up the same amount of fluid just a heads up. This has been the case on also a few trailblazer ss's ive done which got switched to the catchcans.com version
+1 for the catchcan.com
I ordered one for each of my 2 vehicles. Shipped them priority and got them in 2 days. They are of excellent quality and really nice machine work. After inspecting them out of the box they are worth every penny and actually as a former machinist, probably quite a bit more than what they charge for them. I'll be installing next Saturday unless I get off work early one of these days
Goodinblack
I Like Tacos
Dirty South
Apparently 2009+ are different?
You can't twist the intake side off....
Had to remove the two pieces with a socket (red circles). This allows you to lift the harness up and swing the pipe assembly towards you.
08grey
Lee looks like your hoses are backwards
08grey
Good thing you took pics. Clean install. Btw how much was the new tensioner and idler. I want to do mine.
Yuko04
"SquareBODluvr"
MN
+2 on that.
Ive heard horror stories about some of the homemade put-together cheapies..Not knocking anyone else....just was a no brainer for the amount it catches and all the reviews.
Jiggy-J
Durobans
