SunlitComet
OBS Jedi-Do Good
unknown at this time.
+1 for e fans, what kind of temp sensor are you using? I'm looking for a dual range to go with my mk8 dual speed fan and Volvo dual relay
Right now just the included controller for the flex-a-lite 280 fans. It is a single stage unit with a prewired sensor that affixes to the radiator fins.
2door2wheel
New York
slid on an ice patch and crashed into a boars head truck. fortunately the only loss was the lower valance and the plastic bumper strip
2door2wheel
New York
Hope the trucks contents were okay.
nothing but a bruised ego.
the real kicker is that i drove this truck with a cracked valance for like 6 years and last month i finally replaced it. 2 and a half weeks later this happened .... you cant make it up! :emotions122:
chaingun427
OBS Mad Scientist
Mooreland, OK
Nice, those are cool for the adjustable temps, I was thinking of getting one of these guys here but i'm not sure if the temp ranges would work for a 350 or 383 any thoughts?
it's a 3 pin sensor that closes ground on pin one at 190 and opens again at 209, then closes 2 at 209 up to 226. I'd also wire in a manual override that's connected to the ac pump so that when it's on the fan is on setting 2.
SunlitComet
OBS Jedi-Do Good
Was talking about Boars head truck.
---------- Post added at 02:12 AM ---------- Previous post was at 02:02 AM ----------
The open/close temps seem backward but that is about right. Sounds like it will work just fine. Mine is set now where it turns fans on when the ECT readout on my Scangauge2 (PCM not actually controlling fans just yet) sees about 210°F or more and when they shut off it reads about 193°F. It has an a/c trigger as well as bypass on/off (unused at the moment) functions. Some diagnostic lights on the module as well. Only tweaked it once after initial install to perfect the temps. I expect it to have no issues with a 383 later. My setup is quite effective and can handle more then it currently does now. Eventually the PCM will control them at multiple speeds and the current controller will be used on an auxiliary fan installed elsewhere at a later time.
2door2wheel
New York
---------- Post added at 02:12 AM ---------- Previous post was at .
ha ! thanks a lot !
---------- Post added at 09:46 PM ---------- Previous post was at 09:44 PM ----------
broke one of his front wheel studs but there was no cold cuts all over the highway im sure the honey glazed ham was fine.
knucklebuster283
Bethpage Tn.
Two weekends ago rebuilt the front end on the Yukon. Today replaced the heater blower motor. Tomorrow start chasing the blinker gremlin, have already changed the flasher relay.
bigal11419
Queens, NY
Replaced the fuel pump, fuel pump relay, front rotors and pads (PowerStop K1970 severe duty kit), and water pump
'99_Tahoe LS 4WD - AZ
Phoenix, AZ
Ok, so I bit the bullet and did the Hydroboost conversion (vacuum to hydraulic). WOW what a freaking difference it made! I did not have enough cabbage in the piggy bank to put on the power steering pump cooler but will do that in a month or so. It's okay, I think, since it is still winter and it does not really get driven that much. I also installed a stock 105 amp alternator as the other one sounded like two skeletons having sex on top of a tin roof!
:chair:
jerryjoe28
That Guy
cabot AR
:chair:
congrats on the up grade! but one question...... How dow u know what two seletons having sex on a tin roof sounds like? LMAO that must be the 51st shade of grey
CSX
Door work - replaced both interior and exterior door handles, power door lock solenoids, had the door panels reupholstered, and lubed all of the power window tracks.
Nothing exciting, but definitely necessary.
BirchyBoy
I got an over-the-phone trade in value for a new Jeep Grand Cherokee. The Jeep has a selling price of $42k. They offered me $560 for my Yukon which is a '99 with 179k. My tires are worth more than $560. I told them to pound sand.
wwiizz
