Help me decide!!!
1highbaldguy
So Cal
well, heres the deal. i want to lower my 05 tahoe either 2-3/3-5 inches. the thing is im going to keep the stock 16s during winter so we can still hit the mountains. im trying to find the whole shebang. coils, keys/spindle, shock ext, shocks. heres a few setups i have in mind, any pros and cons of each setup will be great.
2-3/4 (keep it simple)
keys
belltech procoils (3-4)
shock ext
bilsteins all around
or
2-3/4
16in mcgauhy spindle (modded to get full steering)
shock ext
billsteins all around
or
3-3/4
djm lca (can i crank up the tbar a bit to get a 2-2.5 in drop?)
shock ext
shocks? i know bilsteins will work out back, but what shocks can i run up front with the djm lca?
ill be using stock size 16s and 24s (305/35). i would like the front to sit a tad bit lower just incase i have to pack in friends, luggage etc. any help is greatly appreciated! thanks guys
MOBmentality
Has a $25,000 Punch
djm lca (can i crank up the tbar a bit to get a 2-2.5 in drop?)"""YEP"""
shock ext
i LOVE this setup... not sure about front shocks.. but im sure belltech has something thatll work
1highbaldguy
So Cal
3-3/4
shock ext
oh ya, alignment wont be an issue right? i would hate to get the LCA setup and have to get the UCA just for it to align.
NORCAL SS
SUV SUSPENSION GURU
djm 3 inch lower a arms ive never had issues.
spindles/keys for 3 inches i have had issues for alignment.
---------- Post added at 12:18 PM ---------- Previous post was at 12:17 PM ----------
honeslty id do a 3/5 but you can do a 2.5/4 if needed with the belltech pro coils. Sent yah a price on all of it also. If you see it anywhere for cheaper shoot me a link ill beat anyones prices.
1highbaldguy
So Cal
hmm i didnt get the PM? maybe resend it. thanks
whats the difference between the belltech procoil and their regular drop coil? do they ride the same. im looking for something that will ride nice and firm.
NORCAL SS
SUV SUSPENSION GURU
THE PROcoil is a 4 inch drop coil but you can set it up for a 3 inch also by the spacers they give.
id do 3/5 DJM drop with belltech street performance shocks all around
or
the set up your looking to do with the 4 inch rear belltech spring. Then add in the belltech front/rear swaybars.
1highbaldguy
So Cal
or
id drop the rear 5in but i think its a bit much. i would if it were my tahoe, but its my chicks.
what type of shocks would i need for the djm lca? eye to eye setup?
damn too much stuff i cant make up my mind...
1highbaldguy
So Cal
who makes shocks for the djm are comparable to bilstein hd? i only wwant to drop it once and not keep switching up the setups. trying to get it done right the first time...
NORCAL SS
SUV SUSPENSION GURU
Honestly befor eyou go buying shocks id see how the thing rides first.
1highbaldguy
So Cal
that might be a good idea. the shocks have 65k on em though. so we'll see.
edit - will i have any alignment probs of i use djm arms and crank them up a bit to get a 2.5in drop?
MOBmentality
Has a $25,000 Punch
when you do 3in drop on arms the alignment is like MAXED out.. so torquing it up to 2.5 might actually HELP you get a zero alignment
ZaZaZazzels
