Kelderman air ride
Frey522
Hi everyone,
I have been doing ALOT of research and I think I may have found an airbag replacement for our coil springs. Its from Kelderman suspensions.
The kid they make is for the 2007-2014 Tahoe suburban, and Yukon. But after doing some looking at their installation instructions. and climbing under my Tahoe many times. I think it may work.
If anyone knows if the rear end is the same or different, and what is different about it please let me know.
Ill be calling kelderman tomorrow to see what they say.
here is a link to the kit.
http://kelderman.com/gmt900_tahoe_yukon_denali_escalade_lowering_kit_air_suspension_rear
thanks
F
Frey522
SWEET ! are you 100% sure? it just a big $ risk and work load.
my hope is to do this rear airbags and then front coil over conversion from Atomic.
Just need to purchase the springs and shocks to go with it.
Ben
PCB, FL
If he says they'll work they'll work... :roflbow:
NathanJax
Vacation Nathan
Jax, Fl
The rear will work.
SWEET ! are you 100% sure? .
Yes he's sure. He works at Kelderman, he had this setup on his old Yukon. I have that setup on my Yukon, and others no this site use or have used it before as well. Do a search for Kelderman on here and there is plenty of info.... Info on mine can be seen by clicking the picture in my signature.
yates ™
Resident Apple hater
Iowa
As far as I know the rear has not changed through the NBS and NNBS.
yates ™
Iowa
where would the compressor assembly mount in a NBS?
The easiest option would be we could do is what we call a wireless one, it is a small compressor with with a valve block and wireless remote. The compressor can be installed where ever you would like or have room. The remote shows the pressure you have in the bags and pressure can be adjusted from the wireless remote. This system uses a one way valve so the two rear bags will pressure adjust after the valve.
Picture of the remote
Picture of the compressor, link to compressor specs
livingez_123
Sandy, OR
I wonder if they would just do the rear kit with no compressor?
What lbs are the bags rated at?
yates ™
Iowa
$600 for the rear brackets and bags. I am not finding the rating for those bags but I will get you this info shortly.
:lol2:
Does it make ya shake your ass, Brandon?
JasonW4141
