clandr1
Hi everyone,
I could use your help. My A/C compressor won't reliably cycle, despite proper condenser airflow, proper refrigerant charge level, etc. I've ruled out the pressure switch that is attached to the drier/accumulator, and when I jump the A/C relay, it works perfectly, and low and high side pressures are within the expected range.
I gave up and took it to a local shop about two weeks ago. Their initial diagnosis was a bad A/C clutch. So, I took it home and swapped out the drier/accumulator and the A/C compressor with Genuine GM and Denso units, respectively.
I took it back to the shop to charge it with refrigerant and they called saying it still wasn't working, and they would diagnose further.
To date, they have supposedly validated that all inputs are correct, but for some reason the "on" command is not getting to the A/C compressor clutch.
Using a Tech2 type scanner they are able to command the AC compressor "on", and it works, but cannot get the system to perform this itself.
They have supposedly confirmed that all sensors are good, the HVAC control module is good, and the PCM is sending the right signal when the A/C is turned on inside the cab.
At this point they are doing continuity testing because they think it might be a broken wire, or a bad connection.
One piece of info that may be critical - it seems my A/C woes started shortly after I replaced a battery. I've done this probably close to a dozen times on this truck and it's never caused any issues before.
Any ideas of what we may need to check next?
