noJeepshere
Bountyfull, Utahrd
You can get away with 5 lugs fine, that's what the half ton 2wd trucks run on, but it's not a very tough job to replace the stud, in fact my tire shop did it for free during a tire rotation.
chaingun427
OBS Mad Scientist
Mooreland, OK
Hammer out the bad stud and use an impact gun and new nut to seat the new stud takes all of 20 minutes.
---------- Post added at 01:27 AM ---------- Previous post was at 01:23 AM ----------
Finished wiring on the secondary fuse box, new power ports, hidden 110 inverter, and secured my 02 center console to the floor (with quite a few washers as shims) installed new 02 towing mirrors and wired in motors on those, prepped front air dam for installation and have her a bath. New radiator and upper ball joints just came in so that's a project for this weekend.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
one question , when removing the front right wheel , some ******* with an impact gun cross threaded the crap out of one lug. i had to grind it off , but the stud is no good anymore. can i get away with 5 lugs on these wheels and be safe?
replace it. and get rid of the spacers.
96Taho
youngstown,ohio
I Got New Stock Wiper Cowl Ordered , Had Custom Solid Cowl But It Was Not Fitting So Back To A Stock One That Fits..... Still Waiting For Interior Guys To Finish All My Interior And Install it..... Hopefully by end of july i have everything completed
domer94
northwest NJ
should i get one at the dealer , or is there a generic 14x1.5 stud at napa etc?
i only put wheel spacers on the rears and they went on with no issue in a safe manner. the front wheels are as is , but the lug issue was discovered with taking off the original wheels.
Gzes
the drifting 2dr
Wichita tx
AutoZone will have the studs. One time on my old silvi the lugs were not tight well they blew off on the highway and destroyed them I put new ones on from auto zone
noJeepshere
Bountyfull, Utahrd
Any auto parts store will have the correct stud.
And if you take a tape measure you'll find your rear wheels now have a 4" wider track than the front. It is not the axle that is narrower than the front, but the body is wider in the back.
96redsport
Altoona, Pa.
Wired in the MSD box and put in a MSD coil, MSD cap and rotor, MSD super conductor wires and Autolite XP605 plugs.... Just need to find wire loom to fit the 8.5mm wires...
SunlitComet
OBS Jedi-Do Good
Chasing a power steering leak. Seems I made need a new pump.
shaft seal?
---------- Post added at 05:39 AM ---------- Previous post was at 05:38 AM ----------
you forgot the dizzy. without it your system it not purebred.
SwampHound
Alabama
shaft seal?
I'm assuming you mean the steering shaft? First time dealing with a power steering issue, so sorry if its a dumb question.
SunlitComet
OBS Jedi-Do Good
pump shaft seal. the pulley does not have a shaft it just mounts to one:naughty:.
---------- Post added at 10:41 PM ---------- Previous post was at 10:36 PM ----------
bought my first tail for the suv. big tex 5X8. $634 out the door. 1200lbs load capacity.
RI95Tahoe
Rhode Island
Going to attempt to pull out the turn signal switch today. Want to make sure I can get it out before I order one, may have to pay someone else to do it. :Good or Bad:
omaha
another gov lock bites the dust
Heres whats left of my rear gov lock. RIP lil buddy
Drewphil
