BirchyBoy
have the wave forms of front and back sensors looked at first. if rear sensor level is low and flat then the sensor may be the issue. if it is active and looks like the same kind of activity as the front then the cat is likely the issue. and you can just bolt on new complete cat assemblies if you like.
I'm going to take a peek underneath it first to see if the new sensor worked itself loose; hopefully that is the case and I fix it. If not, I'm taking it in Wednesday for an oil leak fix and I'll see if they can scan it then.
Chevrolado
Redondo Beach, California
Got some freeway miles on the new motor. Only about 60 miles, but still good to see how it performs at freeway speeds. Cruising at ~70mph, just under 2k RPM, just purring along.
I need to adjust the timing a little further to get it closer to 0. It has a little issue of pinging when I step on the throttle to pass someone when cruising at about 60-65. Before it kicks down in gear it starts pinging..
SwampHound
Alabama
Sank it yesterday. Hopefully have it out today or tomorrow.
Sent while drivi-
BirchyBoy
Oops is right! Are your nerf bars heavy-duty enough to act as rock sliders? I've looked at the website but can't get a feel for how sturdy they are, particularly the mounts.
Gzes
the drifting 2dr
Wichita tx
It got stuck in that little? Had the 2dr up to the doors once n got it out by engaging 4 hi
SwampHound
Alabama
Its not in mud, its in water. The other side is what sank down. If I didn't I have an open rear diff it probably wouldn't have happened.
Sent while drivi-
---------- Post added at 03:17 PM ---------- Previous post was at 03:16 PM ----------
They bolt to the rockers, so probably not strong enough to act as rock sliders.
Sent while drivi-
BirchyBoy
Mine is up on the rack getting an alignment. The shop called and said the ball joint boots are cracking. He said they aren't worn, but I'll have to be vigilant with greasing them and keeping an eye on them.
He told me that just the boots can't be replaced and I'd have to replace the whole thing when they're ready. The "Energy Suspension 3.18124 Hyperflex Master Kit" says it includes ball joint dust boots. Is that something different?
99YukonSLT
Ohio
Put a new belt and tensioner on the other day after work. It'd been squeaking all winter and driving me nuts.
GTOHOE
I put new door pins and bushing in,new GM door handle outside,lock actuators both front doors. installed my new led bumper lights projector headlights and my DDM HID 6k w/upgraded harness..broke DR door handle inside think the rods need some grease order DR/PS inside handles :gr_guns: I got a bunch of parts to install been buying parts all winter and its starting to warm up!! been at it since 11 am till 10 pm ohhh even got my rear wiper working and new 14'' wiper blade on..Winning i like my black led bumper lights gives the ole hoe a newer look. My headlights have halos and i'm not to into it..Kinda to ricey for me IMO..
nicliv
Cuba, Mo.
New sounds
Alpine CDE-141 Head unit
Alpine KTP-445 Power Pack
Kenwood 415 4x10 rear
Polk MM651 6.5 front
Elf 2 channel Amp bridged 250 watt powering a RF Punch 10 sub
Boston never sounded better
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i would verify that with energy first.
retorq
Kingman AZ
Ordered matching rims and tires for the front. Went with 255/50/18s on Mamba M13s up front, 265/60/18s out back for that old school raked look.
BirchyBoy
Ooooh, I like those. No love for rotating them, though!
BirchyBoy
I had the "last" oil leak fixed yesterday and an alignment done. The shop checked out the P0430 code and told me it was a faulty cat...no shit. They did say that the other cat had been replaced but the bad one is the most difficult one. They said it would be easier to put a whole new system in but I don't need to do it until it needs an emission test.
First time at this shop and they seemed like good, honest folk. Time will tell.
---------- Post added at 09:36 AM ---------- Previous post was at 09:33 AM ----------
They get rotated every day when I drive.
Touche'
Phlipnstik
