AzTank
Phoenix, Az
what did I do today? i found out why the ac doesn't turn on in my truck. Turns out the ac heater control is all cracked and brittle. searched all the local wrecking yards and came up dry. stupid arizona weather forcing me to have ac for my daughter.
Monstar_est87
City of Angeles
Its should still work even if the side tabs are broken... How do the connectors and connections look..? Mine was bouncing around in the dash for a while but still worked...
qukon 95
wedensday i replaced my EGR valve got the power back.
NOTE: don't get the $36.00 EGR That won't work right you need to
get the $49.00 EGR valve at autozone .
retorq
Kingman AZ
Just got back from a long ass drive, was supposed to pick up an engine from a guy here, got the run around as I suspected I would. Ohh well, onto other projects lol
AzTank
Phoenix, Az
ah they were trashed. all the connectors were broken to the point where it wasn't powering on. The connection on the right was split in half and crumpled. Found a replacement in a wrecking yard for 60. Filled up the system and i have frosty air now.
Monstar_est87
City of Angeles
Oh yea that will cause failure for sure... I had a temporary hvac control from a truck during the winter it sucked not having rear defrost... Switch that out asap...
KPOD
Michigan
Plasti-dipped my front and rear bumpers, now I just need to find some nice 17x9 black rims, throw on some 33s, and tint my windows.
---------- Post added at 04:28 PM ---------- Previous post was at 04:22 PM ----------
Got my GMC amber corners in for my Chevy. Whoops.
You want to buy some clear corner ones? I had some from LMC I used for a month before deciding I didn't like them and went back to amber. They are these ones, http://www.lmctruck.com/features/cd/CDER8.htm
Gzes
the drifting 2dr
Wichita tx
He's jus trolling. But dipped tails might be something you might wanna try. It's a lil too dark for my taste tho
Kevostradamus
Brand new drivers power mirror and new alternator! Thursday is oil change day, touch up some problem areas, paint some spots on the frame and maybe tint the tail lights!
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Don't buy the $49 one from autozone get the oem which costs more.
---------- Post added at 08:28 PM ---------- Previous post was at 08:28 PM ----------
That is wrong on so many levels.
---------- Post added at 08:32 PM ---------- Previous post was at 08:28 PM ----------
I managed to blow out a wheel cylinder and destroy most of the inside paint on a one year old aluminum wheel. New Cylinders, shoes and hardware on the way with a vacuum bleeder kit from mityvac as well. Who knows perhaps with the new shoes i might actually get the parking hardware to fit so i can actually use it for the first time in almost three years. In an unrelated job i also bought a OTC leak down tester for work.
TahoeLimited
Fountain, CO
Bought an 00 Limited Yesterday, Installed New Rotors, Bearings and Pads Today
Bought it yesterday, and the only thing it needed was a new brake rotor (was warped, and makin' me undulate as I came to a stop. Decided to do both rotors, the pads (perfect timing...pads were just about shot) and the bearings as well. She's stoppin' smooth now...
Actually, the first thing I did was wash it. But, being so excited to drive it, I got caught in a drizzle and will need to rewash it!
95escahoe
Bought it yesterday, and the only thing it needed was a new rotor (was warped, and makin' me undulate as I came to a stop. Decided to do both rotors, the pads (perfect timing...pads were just about shot) and the bearings as well. Call me the smoooooth stopper.
Nice looking Limited
Sent from my HTC One X using Tapatalk 2
Drewphil
