How to MarkVIII your OBS on a budget..!
oakdog
I did mine a little different. I bought the one piece adjustable fan controller for 40 bucks and had no problems with overheating or ac. I am running a 180 thermostat and it stays around 180 185.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
oakdog
Monstar_est87
Monstar_est87
City of Angeles
Yea I did my set up the way I did bcuz I went through 2 O'riley and 1 AutoZone temp controllers... The relays kept burning up... Lead to a cracked rad and failed water pump... The fan draws as high as 60 amps... But if u got 1 that works 4 u great...
saif najd
May I ask what is this?
Regarding the main subject I habe the following questions:
1- why don't we use a Nissan efan control system?
2- I think you have to isolate the efan so no hot air well skip the shrod and return to the efan.
3- I loved the one fan idea instead of the dual system but why you did not continue with the push efan it is easy for you now? 4- why we didn't study the Toyota sequia system? It comes with dual push and bull efan!!?
5- why you didn't use another after market efan controller?
6- can this volvo efan controller take the high amp? (Caused by the efan start?)
oakdog
For one that is not my fan controller you circled on the fan that is the factory chevy waffer fuse. The fuse blew when I put my second battery in(positive cable hit the bottom of the battery tray).That's why it looks that way. Pic was took before I chanced it.
Secondly the truck stays cool 180-185 degrees even with air on. Guarante what you know not what you guess.
Also the fans job is to push or pull outside cool air through the radiator ( depending on where the fan is mounted). If my fan is pulling enough cfm to cool the coolant before it reenter the engine than its doing a damn good job.
saif najd
Please note I am asking because I well do the same but from my experience and experiments I asked all or this I well post my dual efan system to compare It was done by the previous owner I am not pleased with his work but it seems the best so far everything I try failed to outcome this setup thats why I need to nake sure you are right.
---------- Post added at 08:40 AM ---------- Previous post was at 08:39 AM ----------
The picture I was asking about that part because I couldn't find in mine! Nothing like it is install and is it a must?
Monstar_est87
Monstar_est87
City of Angeles
That thing in the picture is on our stock fan shroud... Its something to do with the battery... I can't remember the name off the top of my head at the moment...
saif najd
This is my fan setup:
I think it is taken from a subaru but it is fine I think
oakdog
How much cfm do these fans pull? If you know.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
oakdog
Not bad
---------- Post added at 05:39 PM ---------- Previous post was at 05:33 PM ----------
Monstar_est87 you were right about the mark VIII pulling 60 amps. I haven't had any problems but I am coming up with an alt controller.
saif najd
Looks good... How is it being controlled..?
By 3 relays this the modes:
1- both working full speed to cool it down
2- if no need to cool the the radiator but the A/C clutch kicked ON then single fan will work
3- if both are working and the A/C clutch kicked ON then one of them will work for the A/C and the other will continue for the coolant.
I figured it out soon it was done by the previous owner actually
---------- Post added at 07:34 PM ---------- Previous post was at 07:33 PM ----------
Sorry I don't know I wish I could
---------- Post added at 07:34 PM ---------- Previous post was at 07:34 PM ----------
I believe low is 3200 and high is 4600 cfms... Just off the top of my head...
It is on high all the time
---------- Post added at 07:35 PM ---------- Previous post was at 07:34 PM ----------
Not bad
Thank you
2drhoeon4s
if I knew about this i probably wouldnt have gone with Flexalite dual efans... $$$
Monstar_est87
Monstar_est87
City of Angeles
Not bad
Yea they can draw quite a bit so make sure u get a relay or relays that can take it... And a self resetting fuse aka circuit breaker...
Its all good... Ur flexalite match ur sweet @ss truck...
By the way this one of the most famous mods locally for efan conversion
Good work saif najd... Electric tape and wire loom go a long way 2 protect ur wires and clean things up abit...
MC153
I remember you told me about this when I first got my Tahoe. Just barely found the thread. I wanna do this with a Jegs kit. I will get the fan for $14 from the junkyard. My only concern is the power draw. Will I need to upgrade my alternator? If I have to, this mod will have to wait for awhile.
retorq
Kingman AZ
I ran dual fans with the Jeg's kit for a while with the stock alternator. It's a good idea but you don't have too...
dizhai
