Phantom240
Got my new remote in yesterday, programmed it this morning... awww yeah
However, now I realize I need to replace the two front door lock actuators. *sigh* I'l just have to add them to my list. They're weak, but usually will unlock and lock on the first try.
_Dylan_
STAY FROSTY
I'm going to say nevermind on the CPS, it should throw a code for that which it didn't.
I'd probably start by getting a fuel pressure reading at higher RPMs.
---------- Post added at 02:00 PM ---------- Previous post was at 01:54 PM ----------
Went to the JY yesterday.
Picked up some tweeters with nice housings from a Land Rover
I think they would look good right about here:
Audi push button cupholder thingy and a coil tray thing
ES300 projector fog lights :D
slipping
Rosamond, CA
Nice finds, my jy sucks.
How do I go about checking fuel pressure. Started it up and was running nice for a few minutes, opened hood to look and after a minute started choking and as it died I see a Puff of smoke come out the air filter. Assuming that's not good.
_Dylan_
STAY FROSTY
I went to 3 different JYs to get that stuff....
What's the coolant look like?
The test port for the fuel line is on the back of the intake.
slipping
Rosamond, CA
Its fresh since I added when I changed the heater valve off the side of the road but I did notice a little reddish orange when I wiped my finger inside the radiator hole. I'll test when I get home after work.
96redsport
Altoona, Pa.
Went to the pull it yard and picked up the front door switch panels complete with the switches, 2 rear ashtrays, a working easy entry seat track and seat track trim. Came across an OBS Esky but the center floor console and cluster were long gone.....
Going to Jacksonville Fl. first week of June so I'm gonna hit up the JY while there and see what I can scrounge up...
noJeepshere
Bountyfull, Utahrd
Took the Yukon to another shop, guy said there was very little moisture in the system, it held a vacuum very well, and operating pressures looked very good. He did note, however, that the condenser behind the grille was nearly plugged with 14 years of road filth and cleaned it off. Everything is great for a whole lot less than the other place that wanted to replace half the system. :rolleyes:
cent frum a smaert fone
Gzes
the drifting 2dr
Wichita tx
might get a master cylinder off a Nbs for the hoe. Tired of the soft pedal
95BlackTahoe
Edinburg, PA
Well, I went out and finished off the double DIN with the trim piece...
The I decided I may as do away with the steering wheel controls that worked great with the JVC I had, but really didn't seem to like this new Pioneer. I decided to slap in a steering wheel from a 04 trailblazer...
No airbag light, everything working normally...
The old wheel...
Shawn
95escahoe
The old wheel...
Shawn
The new wheel looks great got a write up on what you do?
Sent from my HTC One X using Tapatalk 2
SunlitComet
OBS Jedi-Do Good
unknown at this time.
when you guys quote someone please leave the pictures out of the quote unless it is really needed. it slows page loading and it way the annoying to have to scroll they the exact same thing over and over trying not to miss what is not quote.
_Dylan_
STAY FROSTY
I really like the new steering wheel man. That is going on the to do list for sure if it's an easy swap.
Gzes
the drifting 2dr
Wichita tx
Should be easy. Do steps for removing air bag like unplugging battery then pull plug and take the nut off the middle and if there is another plug for the steering controls then remove and put new one in reverse order
_Dylan_
STAY FROSTY
Nope. Splines are different according to his post on FSC. That's what I was worried about.
Gzes
the drifting 2dr
Wichita tx
They are? The nnbs ones are same spline from what I was told. Then you need a hub adapter like when you put a mono wheel or nardi wheel on a sports car. I had to get a hub to my del sol when I put my sparco wheel on
Drewphil
