VicYukon
Stockton, ca
@Monstar_est87 I actually don't want the front piece I don't like how they look when they get to the bottom of the dashboard. So I know that their is a little gap that shows in front of it but thought I would make a piece/plate cover for it.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i recently started converting to these but the smallest diameter section of the bulb holder needs to be ground open a bit and i removed the lens to put them in. in the end i chose to leave the lenses off for now instead of gluing them back on. Totally awsome. must do the same or bigger for under the dash as the 120° singles( no alterations but horrible output on reading lamps) just dont cut it. http://www.superbrightleds.com/more...-led-bulb-9-smd-led-wedge-base-tower/207/925/
YUKON1999
Yeh I paid 450 and then I found the pocket style for cheaper, those were what I wanted to have but couldn't find them
YUKON1999
does anyone know of a clear cover for the rear cargo lamp instead of that white cloudy cover
96ProCompTahoe
IN
cleaned out the interior a little, hoping to have good weather this coming week to get it out and washed and detail the inside.
_Dylan_
STAY FROSTY
bought a window motor from a mitsubishi and a chevy window switch for my cutouts :)
Goldhawg
Changed my spider from poppets to new style; put new cap/rotor/wires/plugs & volant airbox. Also swapped the steering sensor. Waiting to drive it tomorrow to see if steering improves.
Drewphil
