slipping
Rosamond, CA
U did the body lift? Anythong i need to know so i dont **** up anything else?
Yeah I did the body lift. The steering extension acted like it was gonn be a PITA but it was actually easy. I'm push button 4WD so I didn't have to worry about shifter linkage. I've heard that's a b****. The shroud gave me the absolute most trouble, that and relocating the rear bumper.
Are the BLs on the 4wd different than the 2wd? I have taken all my BL off but not sure if mine has the trans cable extender. Gotta take the seat and carpet up, was wanting to know before I took it all up
Gzes
the drifting 2dr
Wichita tx
Tcase i loosened from the top but it didnt shift. On cable trannys theres no extension you jist move it a lil down the hole. Mines rod so i have to weld in an extension. I jist picked up screw extractors so tomorrow im going at it
---------- Post added at 12:57 AM ---------- Previous post was at 12:50 AM ----------
By not shift is sink down but tomorrow im gonna hurry up n get the bolt out and locktite the new bolts and cut ths shroud and put it all together after the rod
_Dylan_
STAY FROSTY
new pads and rotors
slipping
Rosamond, CA
Just got done ordering new plugs, wires, cap, rotor and k&n this morn. Walked outside and the wife says "what's under your truck?"
Going back in to order a water pump.
Tricky
Illinois
retorq
Kingman AZ
Finally got it in ... gonna hook everything up tomorrow, may have to fix a couple wires, the VSS wires are down to bare metal. :/
Stupid rear end pinion seal is leaky too. :(
slipping
Rosamond, CA
Here are some deal savings online coupons from advance auto. You can order online and pick up in local store.
http://m.retailmenot.com/view/advanceautoparts.com
Thank you good sir! I looked and dont have any advance autos near me.
That looks like fun! (Not being a smart ass - I want to learn)
Gzes
the drifting 2dr
Wichita tx
Damn bolt is still in. I redneck welded nuts on the bolt but no good it keeps on poppin off. I have to thin rod and cant control the arc because im running car batteries and not a real welder lol. Crud has come loose tho so hopefully it cones out tomorrow
stereodesigner
I washed her up, went to check out some all terrains for it...
Now I'm. Trying to figure blackbearperformance or pcm4less
Sent from my DROID X2 using Tapatalk 2
qukon 95
ready for winter
i replaced my LTW DELCO wires and the delco plugs. the
old plugs gap was .059 lol i should have better pick up
now.
knoslf
Thornton, CO
Nice lookin truck! I think I'll take my runnin boards off too, gives the impression that it sits higher, well my suspension is all stock though...
slipping
Rosamond, CA
Thanks dawg. I just don't like seeing that frame. One day it will lay on the ground, but until then ...
Gzes
the drifting 2dr
Wichita tx
test fitted my guard and am stuck on keeping it on frame or lift it up with the brackets and loose strength
Gzes
the drifting 2dr
Wichita tx
If you left on frame could you Fab a filler for in between?
Yea thats what i thought. I had it that way in my ram but idk i might just do it over at the trade school n weld some more diamond plate on there to fill it
Drewphil
