Planning a drop and 22s---Opinions needed
Ninety5PoloZ
Wisconsin
I just picked up a 2000 Yukon a couple days ago and I'm trying to plan some mods to make it mine and not get lost in the parking lot, along with turning some heads too.
Right now I'm trying to stay cheap since I'm currently finishing up the build of my Camaro, but that should be done here in a month or so. So the plan is early spring to get parts coming in for the Yukon, but I like to research before I make purchases.
Plan is in about this order...
55 watt HID lows & 35 watt HID fogs 5000k color
Clear Headlights & park lights
Tint front windows 20% to match rears
Plasti-dip grille shell
Grille insert
Color match valance
3-5" drop
Eibach sway bars
Spohn PHB
TBSS style 22s in gunmetal
305/40/22 Nittos
Debadge & remove running boards
Remove roof rack
Rollpan & relocated hitch
CAI
LTs & catback
Tune
I'm also going to be getting a different headunit and swapping LEDs in place of the factory bulbs.
I'm basically looking for what the best drop is. Norcal SS has been leaning me towards the DJM lower arms and TBSS rear springs, but before that I was going to go with spindles/keys and rear coils. What is your opinion for the best ride and handling and still being able to hold a good alignment? Also if you have any suggestions as far as the rest of the mods go please let me know :)
BTW I'll get some pics after I clean it up this weekend, its been snowing off and on around here and the roads are covered in salt :(
Alex33
NorcalSS knows his stuff. I currently have spindles/keys and the Belltech TB coils on mine and I like it. I'm seriously considering pulling out the drop keys and trying the drop arms and spindles to see how I like that. Only time will tell. I'm in no rush though and I'm very pleased with how my truck rides. I'm on a 274/45/20 tire.
NORCAL SS
SUV SUSPENSION GURU
for 3/5 the kit i offer is great.
here is a customers 3/5 with 305 40 22 I set up. He had the mcgaughy springs in before and then switched to my tb coils and ride is better and sat lower.
You will also need to cut the rear bumpstop brackets off the frame for this set up for a good ride. In my kits I also include new rear bumpstops which no one else does on their kits which I dont understand why.
MrBalll
West Texas
Not trying to thread jack, but why does the kit include bumpstops if the entire bracket is getting cut off? Is it in case the user doesn't have access to/doesn't want to cut the brackets off?
I always thought it was in case they couldn't get the bracket off, but just wanted to make sure.
NORCAL SS
SUV SUSPENSION GURU
If you go 4 inches or more on these trucks and dont cut off the bracket completly the ride suffers. The bumpstop I include with my kit drill and taps into the frame its about 9/16 of a inch tall so that when people come down ******* the rear it doesnt make frame to axle contact.
By cutting of the rear bumpstop bracket off the frame and adding the bumpstops in my kit you still get 3 inches more travel.
If you keep the oe bumpstop bracket on the frame and do a 5 inch rear drop you have 3/4 inch of travel at most.
Max
Mile High
Denver
4/6 on tbss 2s with 285/40/22 nittos:
Rides nice and I can adjust the rear up an inch with the helper bags, critical if you plan to tow anything. I'll probably be swapping my drop keys out for djm upper and lower arms and some QA1 or Fox shocks, otherwise the truck is a hood and esky rack away from being done far as the exterior is concerned. Hope that helps :cheers:
MrBalll
West Texas
Oh ok, I didn't know you put them directly into the frame. Thanks for clearing that up.
Ninety5PoloZ
Ninety5PoloZ
Wisconsin
http://i2.photobucket.com/albums/y36/mcconditioner1/Denali/8-24-11/DSC01698.jpg
http://i2.photobucket.com/albums/y36/mcconditioner1/Denali/8-24-11/DSC01712.jpg
Sexy as hell man, I love your Denali :Handshake: Makes me want to do a 4-6" drop, but I think a 3-5" will be more user friendly. And I plan to tow eventually unless I get rid of a couple vehicles and get a 2500. Helper bags are in my future :)
Norcal SS do you have a setup for a 5.5" rear drop? I would hate to get your setup and cut the springs but it seems like the 5" drop springs sit a touch high for my liking. A half inch more I think would be perfect, but I understand every vehicle is different.
---------- Post added at 11:52 PM ---------- Previous post was at 11:49 PM ----------
^^Or maybe its just the shape of the body that makes the rear look higher because the fender gaps look even. :dunno:
NORCAL SS
SUV SUSPENSION GURU
you can do the belltech springs 5305 since they have dead coils which you can cut and wont affet ride. Ive been using those for 5.5-6 inch now drops.
It would add about $35 dollars to the kit but gives you a easy option.
Dizigidy
NorCal
Tony (Norcal) sells newly redesigned rear belthech trailblazer coils for tahoes that ride real nice. I put em on my 07 avy, absolutely the way to go.
NORCAL SS
SUV SUSPENSION GURU
The tb springs do about 5-5.25 but they do ride nice. Good thing if you put helper bags in they tow perfectly fine.
My kit has the new tb rear coils in it on my kit i listed
Ninety5PoloZ
Ninety5PoloZ
Wisconsin
If I wanted to add these coils instead of the other ones you have in your kit and upper a arms what would the total be?
My Yukon has 160k miles and I'm sure the bushings are getting bad.
Thanks Tony :Handshake:
NORCAL SS
SUV SUSPENSION GURU
The djm.uppers and rear 5305 would add 345 to the cost
Ninety5PoloZ
Ninety5PoloZ
Wisconsin
So at this point would I be better off getting the cornering package? Thats alot for just the UCA. I was planning on getting Eibach Sways...How do you like the DJM sway bars?
NORCAL SS
SUV SUSPENSION GURU
I have no issues with the djm swaybars at all great stuff. the djm uppers are 300 and springs would add the 45. Seeing your truck has 150 k miles i would do the djm upper/lowers and djm shocks in front that would replace the bushings and balljoints and then in rear do the tb coils and I think you will be fine. If you get the cornering package I give a better rate since putting it all together.
Ninety5PoloZ
Ninety5PoloZ
Wisconsin
Thanks again for the fast response, I wasn't complaining about the price, more like just thinking out loud. $875 + $45 + $300, so for a few hundred more I could get the sway bars and have a almost new suspension.
NORCAL SS
SUV SUSPENSION GURU
Depends on the bend production date. The earlier models didnt bend so high up.
OldWYLawman
