Getting message?:"Tighten Gas Cap" or are you Unable to fill your tank? ! Look here !
Travieso
Boooooooost !
Los Skandeles, CA
I ordered that part a while ago and replaced it on my truck. Unfortunately it has not fixed my problem. Is there anything in the engine bay like a solenoid or valve that could be causing this? I've tried to not pay a hefty fee for a dealership to fix this but I need inspection soon....
that blows man, what codes are you getting ?
Same here. Thanks for the great help.
Well here is my 1 day update... installation went fine it was a breeze to install if you have a lift you dont have to remove the spare tire, you will have plenty of room in front of the axle, i did struggle with the evaporation hose coming out them damn clips didnt want to come off, had to stick to flat head screw drivers on each end then pry it off, took me over 5 minutes to figure this out.
Re-fuel and it was clicking like how it used to, it did click 3-4 times but not like before vs every 2-3 seconds. So i'll give it a few days for the fuel system to recognize that theirs a new part in the charcoal canister box...
I reset the check engine light, and so far it hasn't come up, im hoping this resolve my issues either way i will keep you guys posted in the next few days.. hope this works
Sidepipes
SF Bay Area
I bought the canister purge solenoid valve from AM-autoparts.com for $30.50, including shipping from eBay. It came quickly, so now it's time to install it. I didn't have a lift, so down came the spare, and under the Yukon go I!. Just like Travieso, I had a hard time getting the hose clips off, and the mounting tang was a pain, but at last it came out. The new one went in quickly, and, so far, no "Tighten Fuel Cap" message. I need to run a couple of days to see if the engine light goes off, or , get it reset.
So far, so good.
Thanks to all.
ESV_Platinum
P0455 and P0449
Bump can anyone help me with this? Already replaced rear canister solenoid from rockauto or autohauz don't remember.
Light is still on giving those codes....
Cubby
Started to get the premature shut-off at the pump and I remembered seeing this thread, thanks!
ESV_Platinum
still having the same problem, im thinking it has to be a bad wire or something
once again, is there anything that would need to be replaced in the front area of the vehicle to fix this code? for some reason i remember reading something...
kafkaq
This is great info... does anyone have a pix of exactly where to find the evap solenoid? I'm not the greatest mechanic so i just want to verify it before diving in...
scrnchr
Hi folks,
2004 Tahoe LS 4WD
I bought this part: ACDelco 214-2149 Professional Vapor Canister Purge Solenoid
It matches the photo at the top of this thread.
I put the truck up on ramps, crawled under from the rear, and I cannot find the part anywhere! I looked all around the gas tank, above and around the rear axle, followed the fill and vent tubes from the rear side panel to the tank--nothing. There is a small rectangular piece with cables behind and right of the tank, but it's much much smaller than this canister and the wrong shape, and the connections don't seem to match. There are no loose cables or hoses hanging anywhere, so I don't think the part is missing.
Any suggestions on exactly where I should look, or if I bought the wrong part for this truck? I'm hoping I'm not going crazy.....
Thanks.
scrnchr
This is the part I bought, which all the parts websites said is the correct part for my 2004 Tahoe LS.
But this two-piece kit is also available, althought the websites say this is NOT the right kit for my Tahoe.
Here is what I see when I crawl under my truck.
This is near the back of the gas tank. This rectangular piece looks a lot like the one in the two-piece kit above.
This is the Evap Canister mounted on the side of the gas tank.
One of the lines from the Evap Canister leads to the unit pointed to by the arrows in the next three photos. I can't tell if this is the other part shown in the two-piece kit above. Does anyone know what this part is?
Finally, this is a little more forward. I'm not sure what the arrow is pointing at, but I don't think it's part of the evap system. Maybe part of the 4WD shifting system? I have no idea.
Here are a couple of GM diagrams I found, and a couple of pages from the GM manual. I see there is some confusion between "purge valve" and "vent valve". The manual says the purge valve is under the hood, on the intake manifold. But I have looked at that, and the part I bought is much bigger. I think other GM trucks, especially pickups, have the part I bought near the gas tank. And I think what I bought is a "vent valve" regardless of the word "purge" in the name of the part.
Any ideas on what I have here?
THANKS.
scrnchr
OK, the cylindrical part is a redesigned replacement for the box shaped part at the back of the gas tank. Got it replaced and am waiting for the EVAP check to complete (reset the codes). Now I'm fighting the dreaded P0101 MAF DTC problem. Think I'll buy another GM..... um, no....
Eschrichtius
So which picture is the one that shows the Solenoid?
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Umm.... They all have their problems. Nobody makes a perfect vehicle. They all aim for satisficing.
No, I didn't misspell satisfying. Satisficing is a real word.
Sent from my myTouch_4G_Slide using Tapatalk
Eschrichtius
So I just finished installing the part; I haven't been to the gas station yet but I will soon. I took a pic showing the placement of the part on the truck:
You can see it with the wire loom and the hose coming from it, in front of the axle attached to the underbody with a clip which is somewhat difficult to remove. The hose clip is a little tricky but came off easier than the clip for solenoid. Scale of 1-10 1 being easy 10 being hard I'd say it was a 3. Mostly because of the awkward positioning for me to try and get the clips off. Would've been easier on a lift. Only necessary tool was a flathead screwdriver.
domin8
Just Plinking
Damn all of you. I read this thread, and even posted 2 weeks ago. Now I'm suffering the same problems. Got the fuel cap warning message earlier and the P0449 today. Looks like I'm fixing the truck on Thursday.
Edit:~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
There is a TSB on this as of April 2011 for NNBS trucks. Bulletin number is 09-06-04-028C. There is a revised evaporative emmissions (EVAP) canister vent solenoid (CVS) valve assembly. The revised EVAP CVS valve vent pipe attaches to the fuel tank filler neck. New p/ns are 20995472 for the EVAP CVS valve assembly and 19257603 for the jumper harness. Expect to spend ~$80. Service department can provide you with detailed install instructions should you want to attempt this. Looks very simple and will attempt to do this myself tomorrow afternoon. Book time for the dealership is .8 hours. I hope this helps.
Eschrichtius
I'm still having trouble with this. The first day I filled up after the install (about two weeks ago), it clicked twice initially trying to pump gas, but then let me fill the whole tank. So I thought the problem was solved. Today I go to fill up again, and it's back to square one. Clicking every f#%^ing 5 seconds! This is annoying as hell...
Any more ideas on fixing this? Did I just waste $25???
domin8
Just Plinking
Read my post above yours. It tells you everything.
scrnchr
I don't know if that new kit will solve your problem or not, Esch. My issue was the code being thrown and not passing emissions. I never had the clicking off while filling problem.
Anyway, I bought a MAF sensor at a junkyard for 40 bucks, popped it in and the P0101 code went away. Then the truck got stuck in 4WD. I ended up replacing the transfer case encoder motor. Royal pain in the butt. I cannot allow myself to buy any more GM trucks...
Eickybobby5050
