Sidepipes
i just ordered mine guys i will keep you guys updated.. on my results
Same here. Thanks for the great help.
I ordered that part a while ago and replaced it on my truck. Unfortunately it has not fixed my problem. Is there anything in the engine bay like a solenoid or valve that could be causing this? I've tried to not pay a hefty fee for a dealership to fix this but I need inspection soon....
that blows man, what codes are you getting ?
P0455 and P0449
OK, the cylindrical part is a redesigned replacement for the box shaped part at the back of the gas tank. Got it replaced and am waiting for the EVAP check to complete (reset the codes). Now I'm fighting the dreaded P0101 MAF DTC problem. Think I'll buy another GM..... um, no....
I'm still having trouble with this. The first day I filled up after the install (about two weeks ago), it clicked twice initially trying to pump gas, but then let me fill the whole tank. So I thought the problem was solved. Today I go to fill up again, and it's back to square one. Clicking every f#%^ing 5 seconds! This is annoying as hell...
Any more ideas on fixing this? Did I just waste $25???
Read my post above yours. It tells you everything.
Sent from my myTouch_4G_Slide using Tapatalk
