Official 00-06 Tahoe/Yukon/Escalade drop guide with pics...
NORCAL SS
SUV SUSPENSION GURU
2002 Tahoe
Front: Upper and Lower DJM control arms
Rear: DJM TB springs
Tire: 275/50/20
Front shocks: DJM
Rear shocks: Belltech Street Performance
DJM rear hardware kit and free travel mod
looks good what does it measure from ground to fenderlip>?
rollpan in rear are you running the spare underneath also?
SS HOE
Wilson, NC
Tony, I am measuring 33" in front and 33.5" in rear
Street scene rollpan
No spare bc diffirent trailor hitch(sir michaels) for rollpan
Got those shocks on Monday. Thanks
NORCAL SS
SUV SUSPENSION GURU
no problem how do you like the street perf shocks on the rear?
yeah if you had spare tire in and rear bumper still on you would be under 33. if you ever decide to go lower you can drop the djm tb springs in and relese front keys a little and be at 32.75 all around and ride great still.
ghost
Senior Member
Model/Year/2x/4x/AWD:
- 2002 Tahoe Ls 2wd
Advertised drop:
- 2.5"/5.5"
Fender height front/rear:
32.5" Front and rear
Front:
- T-bar keys : eibach
- Shocks : DJM
Rear:
- Rear hardware kit
- Springs : DJM Trailblazer
- Shocks : DJM
Wheels & Tires:
- Wheels : 22" Boss 332's
- Tires : Falken Ziex 305/40/22
Overall - Ride is pretty good. Still not completely satisfied, but theres plenty more i can do to make it better. Haveing only keys in the front is a terrible idea! I still need to get everything color matched but for now i think shes ok.
mobile%20pix%20059.jpg 208314_1911134308722_1552811976_2008730_3698378_n.jpg mobile%20pix%20062.jpg mobile%20pix%20060.jpg 207476_1911142468926_1552811976_2008734_3004635_n.jpg
Nortex
01 tahoe lt 2wd
Front
Mcg drop keys
shocks stock
Rear
Mcg 3" coils
shocks stock
wheels/tires
20" oem LTZ
285/50/20 no rub
Ride
Could be better, needs drop shocks
carcrz
Georgia
- 2001 Yukon 2x SLT
Advertised drop:
- 3"/5.5"
-32.00/32.25
Front:
- LCA's : DJM 3"
- UCA's : stock
- Spindles : stock
- Sway Bar : Stock
- Tie Rods : stock
- T-bars : stock
- T-bar keys : stock
- Shocks : DJM
- Steering : stock
Rear:
- UTA : spohn
- LTA : spohn w\DJM hard ware kit
- Springs : DJM 4" Trailblazer
- Panhard : spohn
- Sway Bar : stock DJM end links
- Shocks : DJM
- Air Assist : None
Wheels & Tires:
- Wheels : 26' U-2 55 B/M
- Tires : Pirreli 295-25-26
Considered upgrades:
- DJM uppers to ease UCA balljoint angles.
Brief impressions of setup:
rides better than the 2\3 drop i had from belltech
cadtorque
carcrz, what are those side skirts that you're running? i'd really like to get something like that to take the place of my factory denali running boards on my '02. Super-clean look!
Knobz
Santa Cruz, CA
- 2003 GMC Yukon
Advertised drop:
- 5"/5.5"
-30.25/32.00
Front:
- LCA's : stock
- UCA's : stock
- Spindles : BellTech
- Sway Bar : Stock
- Tie Rods : stock
- T-bars : stock
- T-bar keys : DJM
- Shocks : BellTech
- Steering : stock
Rear:
- UTA : Stock
- LTA : Stock w/ DJM relocator kit
- Panhard : Stock
- Sway bar : stock
- Shocks : BellTech
- Air Assist : None
Wheels & Tires:
- Wheels : 20" Ultra's
- Tires : Toyo Proxes 285/50/20
- DJM upper control arms, Spohn adjustable panhard bar, Spohn UTA's & LTA's
Pics:
Travieso
Boooooooost !
Los Skandeles, CA
- 2006 Chevy Tahoe Lt 2x
Advertised drop:
- 2.5" / 4-5"
-31.50/32.00
Front:
- LCA's : stock
- UCA's : stock
- Spindles : McGaughys 33004MGY
- Sway Bar : Eibach 35mm
- Tie Rods : Stock
- T-bars : Z71 Bumpstops
- T-bar keys : 3/4 Ton Purple Keys
- Shocks : Belltech Street Performance
- Steering : Fabricating shock stabilizer
Rear:
- UTA : Stock
- LTA : Stock
- Springs : DJM Grey Coils
- Panhard : Stock
- Sway Bar : Eibach 32mm
- Air Assist : Stock
- Remove Factory Bump Stops - Travel Mod
Wheels & Tires:
- Wheels : 24x1o MOZ Astroplane
- Tires : Hankook Ventus 305/35/24
- Switching over to TB coils and DJM End Links with Help bags on the back or bagging the back and a Spohn adjustable Panhard bar
Wish the truck rode like how it rides in the front nice and smooth, unfortunately with having the DJM coils it rides like shit in the back, With having such a small sidewall it kinda comes with its territory of having big wheels with little sidewall, Hoping in the near future i'll eventually upgrade to the TB coil with DJM End links should take care of the truck nicely, or might even go with a bag set up in the back..
Picture of the way the back sits
carcrz
Georgia
yeah those are street scene side skirts
Alex33
- 2000 GMC Yukon SLT 2WD
Advertised drop:
- 4/5.5
-30.125/32.00
Front:
- LCA's : stock
- UCA's : stock w/ BellTech camber bushings pressed in
- Spindles : McGaughy's
- Sway Bar :Stock
- Tie Rods : Stock
- T-bars : Stock
- T-bar keys : McGaughy's
- Shocks : H3 Bilstein HDs
- Steering : Stock
Rear:
- UTA : Stock
- LTA : Stock w/ McGaughy's Axle Reloc Kit
- Springs : BellTech 4230 TrailBlazer Coils
- Panhard : Spohn Adj
- Sway Bar : Stock
- Shocks : Bilstein HDs w/ extenders
- Air Assist : Removed
Wheels & Tires:
- Wheels : 20" Boss 330
- Tires : Goodyear Eagle GTII 275/45/20
- Helper bags in the rear, stainless brake lines up front because the brackets on the stock ones don't fit the spindles and make a lot of noise, possibly the 6.5" DJM TB springs.
It rides very well, much better than my 2/3 w/ autoride shocks. Overall I'm pleased, a little lower in the rear and I would be very happy.
d!!!
Just lower mine with a belltech kit from Tony yesterday :)
Stock height
2/3 drop
The back should come down a little bit once the coil break in
khalilrb26dett
NOLA
Thought this might be a good idea with so many asking about drops...if it doesn't catch on it'll just fade away...if it works maybe sticky it?
This idea is to get a collection of information from everyone on their respective setups with pictures so anyone looking for pics/results/ideas/etc can easily see what has been done & is possible. Edit & update your post as you see fit & as you make changes.
Here's my setup & a possible template to work off of...
- 2003 Tahoe LT 4x4
Advertised drop:
- 3"/5.5"
-31.75/32.25
Front:
- LCA's : DJM 3"
- UCA's : stock
- Spindles : stock
- Sway Bar : BellTech
- Tie Rods : Custom 1" DOM w/ 3/4" chromoly teflon lined heims
- T-bars : stock
- Shocks : DJM
- Steering : KYB stabilizer
Rear:
- UTA : C3Fab adjustables
- LTA : C3Fab adjustables w/ DJM relocator kit
- Panhard : Spohn adjustable
- Sway Bar : BellTech w/ DJM end links
- Shocks : BellTech
- Air Assist : None
Wheels & Tires:
- Wheels : 22" Boss 330's
- Tires : Nitto 275/40/22's
- DJM uppers to ease UCA balljoint angles. Noticed occasionaly popping from stock upper joint. Otherwise, nothing.
Overall, the ride is firm but not stiff. The suspension has a progressive rate feel to it. Normal driving it's really
tame but it takes corners incredibly with little to no body roll & my confidence is gone long before any talking from
the tires.
Pics:
Good idea? Bad idea?
Cameron
I have the LT Autoride 2WD. Does make it more difficult?
kev92gt
New to this stuff but what is the cost ballpark? I have a 03 yukon 4x4 that is on factory 16 and i could smuggle people in the wheel wells if i had to. I would love a 3 to 4 inch drop but dont want to kill the ride as it the family ride.
Knobz
Santa Cruz, CA
You might wanna post in a different thread cuz this thread is a "sticky thread" for pics of drops and stats. Go to Tony's website "www.tbssowners.com". He has pics, stats and prices.
Conedaddy
