scot moore
- Joined
- Dec 20, 2017
- Posts
- 100
- Reaction score
- 81
I have a 2012 Yukon Denali it has around 220K miles. I have had it for 110K of those, since December 2016. I have noticed a small coolant leak, long story short i got some UV dye and was only able to find it in one spot. Not a good picture, but it is around the top drivers side on the radiator. looking through the forums and google looks like this is a common failure.
I am not looking for more work then needed, but I figured it was time to replace the radiator, and looking what else i should do while I am there. I guess that plastic T on the firewall, (I have not gotten the part number yet) the hoses, the thermostat. Water pump is old, but no issue with it yet. i might replace it now, may not. i read maybe i need new orings for the oil or transmission cooling lines. the idler pully and belt also look good, but I may replace them while I am doing it. I don't want to start replacing things just because, as i could always use that money for something else. I also don't want to not replace the obvious stuff that should be done or needs to be done. Now on the radiators, I have several thins. some say only buy ac delco, some say Denso, yet others point to some of the all metal ones on amazon, like these https://a.co/d/0ep2vKNc https://amzn.to/3TltaxN https://amzn.to/4vkgpB9. the thing is besides the brand, I am not sure if i need the 3 core or 4 core, and i have not verified if mine has the oil cooler in the radiator, or only the transmission. I also have a disability that somehow lets me look and order the exact thing i need until it arrives and reality warps and it morphs to the wrong part as i overlooked something stupid or something. and it does not matter how many times i check and recheck before i order it... anyway some help and recommendations on what to order and replace are appreciated. I don't have any issue doing the work myself, just want to make sure I have everything I need so I can finish it when I start and not be down a car. thanks
