- Joined
- May 15, 2021
- Posts
- 553
- Reaction score
- 1,371
CATCH UP:
More later...
More later...
www.enginelabs.com
To expensive. Why not use bearings or the threaded plugs for removal from Amazon?![]()
Plugging LS Blocks to Delete AFM/DOD
Disabling AFM/DOD on LS engines requires plugging the oil-feed holes in the block. Here's a quick and easy tool from Lingenfelter for that job!www.enginelabs.com
Gen IV & V AFM DOD Block Delete Tool Kit
Check out the deal on Gen IV & V AFM DOD Block Delete Tool Kit at Lingenfelter Performance Engineeringwww.lingenfelter.com
For plugging the V4 mode tower holes in the 3rd pic of your previous post.
Thanks. That makes me feel a little better.I don't think it's bad, I think it's a brand new unit. Dealer shouldn't have any problem programming it.
HP tuners won't program a completely blank unit....
I'm surprised you're transmission guy doesn't have the GM MDI2 so he can program a brand new blank unit through GM’s SPS2 (Service Programming System)
This was so much less of a hassle with a good old small block Chevy and a turbo 400 tranny.....
I was thinking this also. I had just watched a video on this exact thing as I've been going down the rabbit hole. Seems very straight forward, maybe it's something you could try to tackle yourself?I honestly don’t know, as I had thought he had one as well.
You are not kidding!
Small block and TH400 in my 1966 C-10 is the epitomy of simple.
Understood. I should have clarified that I was trying to determine if the noise was crankshaft speed or camshaft speed.Diagnosing sound across the internet is a very inexact science.... With that said, check for an exhaust leak between the exhaust manifolds and the cylinder heads. It sounds very similar to that. Does not sound like a lifter to me. If no exhaust leak as mentioned above, pull the valve covers and check for loose rockers.
I have checked all three torque converter to flexplate bolts. All were tight. I used new GM bolts with threadlocker.yeah, very had to say. could he a few things.
beside exhaust, might check for loose torque converter bolts.
did it do it from first crank? maybe cut open the oil filter and check for metal. I can only guess that if it was a rod bearing or something within a 100 miles it would be putting out a decent amount of metal.
Yeah. That is what it sounded like to me.sounds like a rod knock to me![]()
That is what it sounded like to me. See above for the oil filter cutting. I have rotated the engine by hand while observing the flexplate through the starter opening and the hole in the bottom of the bellhousing. I have not seen, heard, or felt any interference or scraping. Torque converter was tight to the flexplate and the flexplate was tight to the crankshaft.That is a hard knock. Pull the oil filter and cut it open to look for metal particles. If you find no metal I would look at the flexplate and see if something is hitting as it rotates. Sorry to hear the bad news.
Nice oil filter cutters are available on amazon for >$25.00. They cut without adding metal to your diagnosis.
