OR VietVet Is Still Throwing $$$ at 2005 Z71
West 1
I still like the older body style and the way they are set up. My burgandy one pictured was sold last year at 135,000 miles and I should have kept it. They are great trucks.
I replaced it with the 08 Denali because my wife liked the ride better in the 08. She is correct and it does steer better but the 03 was pretty unique and I wish I had kept it.
Like yours I had gone through it from end to end keeping everything working as it should. Nice work keeping a nice rig running!
GMT800 2005 Tahoe Z71
Navy Supporting Member
I really feel, at 73 years old, that the Z71 will out live me.
135k was super low mileage.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
This is one generation of GM truck I have yet to have owned. My brother had one and I loved it. It rode and steered so nice and ran beautiful. Was easy to get in and out of too compared to the 900.
West 1
Our 03 and the newer 08 are third cars in the family so they only go about 4K per year these days, mostly hauling and towing work or snow / water ski trips. Handy to have an extra around.
BTW @OR VietVet you got 3" on me I am currently 6'1" 292 LB.
6'2" in high school and then 6'4" by graduation. Nowadays I hang around at 290 lbs. but have been as high as 365 lbs. I want to get down to 275 because I felt best then.
I posted a 2006 Tahoe Z71 for sale in Stayton, Oregon recently but the guy wanted too much for me. He sold it for $18k and had 81K miles and looked like a twin of mine.
I went to Chevrolet Forum and did the VIN Decoder and my MSRP was exactly $100 more than his and was $38, 815.
I wanted it, but at $15k.
LsHart
Senior Member
Now let's talk about the mechanical and maintenance items. This is a complete list of what has been done so far:
1. ALL fluids changed. Brake fluid, trans fluid and filter, coolant, power steering, front axle, rear axle, transfer case, oil and filter....etc.
2. New brake rotors, front and rear and new pads front and rear. New parking brake shoes and all adjusting assembly.
3. All 4 oxygen sensors.
4. Trans Corvette servo.
5. All 4 KYB shocks for Auto Ride Suspension.
6. All cooling system hoses and new tees at the firewall and new reservoir and cap.
7. Both belts and tensioners and idler.
8. New MAF and MAP sensor.
9. New Cam and Crank sensors.
10. New plugs, wires, air filter and clean throttle bore.
11. New rear upper and lower control arms.
12. New high mounted third brake light.
13. New transmission cooling lines.
14. New thermostat.
Did u go Ac Delco on cam and crank?
LsHart
Senior Member
After my tuner tuned it. Tried rock auto and all else but OE on cam. I have a 2 crank intermittent issue.
Was told to go oem on cam to correct. Haven't done it yet cause I'm burnt out on scratching my arms up changing it.lol
Do you have any timing chain slop?
I don't quite understand this statement, "I have a 2 crank intermittent issue."
LsHart
Senior Member
U would get in and start it, the auto key start, and sometimes it will hit but if not on the first it will on the second. No chain slope. It's a brand new l59 with stage 3 upgrades. All new. Tuner told me to change the sensor to rock auto and I did and it's still there. Actually put in rock auto and it wouldn't start. Put in autzones and it's back running. I've read that the oem sensor is the way to go.
LsHart
Senior Member
Did it and still no change. Don't want to but I guess imma have to buy oem cam and crank sensors. Also heard that the eom spec tolerance is tighter that aftermarket.
Well, today it happened. We decided to drive to Oakridge, Or., after my VA had me do an EchoCardioGram, at a local hospital.
Tahoe started and ran fine. Drove to hospital and started fine when leaving. Drove to my favorite restaurant in Oakridge, called Campfire Grill. Started to leave from there and no problems, and then drive up Willamette Highway to a favorite recreation spot for river watching. Several rapids there. We both needed to use the bathroom. Pulled in and shut off Tahoe. Went to leave and engine started to spin for exactly .5 second. then nothing, I mean nothing. No dash lights, no lights at all. I checked connections. All clean and tight. I checked all fuses for anything to do with "ignition". I turned very hard at the key in hopes that maybe the ignition switch had slipped. Got a nice lady with a new Silverado to attempt a jump. Got lights but even after hooked up for 30 minutes, the engine would not spin any longer than 2 seconds and even then at a very slow speed. I did get lights back, till unhooked cables. I thanked her for trying.
I got ahold of a local shop and they brought me a new 6 year MTP-78DT Interstate battery. at a cost of 224.95. I like Interstate Batteries, anyway. $30 service call. He brought tools and I helped hold cables out of the way and the engine fired right up. Drove back to his shop, approximately 5 miles away. Great guy, named Kanyon. This big guy has a great name. Tipped him $40 and at shop we checked the alternator and charging system is fine. The old battery was a 5 year Interstate AGM battery. Sticker on it showed 06/21. 5 years to the month. None/no warning at all. One minute good and charging gauge showing good and then, NOTHING. He likes the Campfire Grill Chicken Fried Steak. I am going to call them tomorrow and set up a meal for Kanyon. I called the guy, we talked and said he had a new Interstate battery and would be there in 40 minutes. Had to finish another job he was on. He was there at 39 minutes. Other calls to tow to home, 44 miles, were between $550 and $600. It was a 2 hour ordeal. **** Occurs!
Ca*Ca?????Really????? Instead of saying Sh**it happens! I said Ca*Ca....
PC can ki******ss my a*****rse!!!!!!!!!!!!!!!!
a1parrothead
