Electric Fan Conversion Question
Matthew Jeschke
Sahuarita, Arizona
Awe sweet, I'm shopping right now for the fans. I thought that might be the case. Looking at NNBS 2500 fans with 7 blades but not for sure how to tell if they are 700W or the 400W.
Trying to locate better fans on Rock Auto... a 2010 2500 Silverado should be the bigger fans no? These HERE say are w/ tow package. However, the width and height don't make sense up with the radiator core HERE for my vehicle 2001 Tahoe. Fans are 9" taller and 5.75" wider. Although radiator core sizes are same between 2010 and 2001! Bit confused? Photos look exact same between GMT800 and GMT900 fans.
No luck on eBay nor local junkyard to source decent fans. It's like 50$ cheaper for the light duty fans on eBay used. Not worth it.
these are 700w. I can't advise on buying anything aftermarket, there are dual 5 blade 700w fans, but unless you can see the motor part number then no way to really verify otherwise unless you are 100% sure it came out of a K5L optioned vehicle
Cadillac fans were too good to be true. I just did a test fit. Would be a nightmare to mount them. They aren't even wide enough. Unless you're swapping JUST the fans or the fan motors this probably isn't a good idea. I'm going to try and return them then just buy the proposed truck fans.
Most of the time, the people on this forum are the “LS experts” not the guy at the wrecking yard. We have done these conversions ourselves so my best advice is to follow what the people here say to do, to the letter. I myself admire the ones who have gone before me and done all the trial and error, because I don’t like to waste my time and if someone else has already gone through the pain of it, why do it again? I do not remember advice to use NNBS fans. The NBS fans for MY 05 up is what I remember using.
Matthew Jeschke
Sahuarita, Arizona
For sure! I shouldn't have deviated from the plan. A little piece of me was like I need to buy something I worked so hard scavenging at the junkyard lol Typically I have some great finds but realized I've picked over everything they had in the lot... Switching to Cadillac's sounded like a good idea but then... Fitment! YUCK.
I've got to ask, a K5L is the NNBS Escalade? I assumed it was a 2500 truck. Searching internet shows a 2 door blazer.
mattbta
Frisco, TX
Fans came in. Now to get the junction block and some factory screws to hold them in
Matthew Jeschke
Sahuarita, Arizona
I got the rebuilt fan junction block from @ScottyBoy I 150% recommend working with him. Saved me grief of eBay (bad parts), scouring junkyard (they didn't have it), and rebuilding the block. He cleaned it up and it looks AWESOME, I mean like new!
Yesterday I got to installing it. Here's a few notes and questions. My goal is to have the EXACT or as close as humanly possible to the same routing & cable management as factory.
Pictures are facing the fender, left hand is front of vehicle.
QUESTION 1 The power lug for fans, I assume it mounted to the junction block left hand side?
I had to grind an ear off the right hand side of photo for it to fit.
QUESTION 2 The wire loom goes under the junction block parallel to the fender?
I tried routing it multiple different ways but that seemed to be the most logical. The red power line / lug was a touch too long though...?
Also it's a VERY tight fit with the relay which I located under that green connector.
QUESTION 3 I assume the relay functions as a OR essentially to turn on the fans when the AC compressor goes on? That it's not on the actual 2005+ trucks, they are computer controlled for AC fans?
QUESTION 4 These two connectors were originally held by christmas tree clips in the void the fan junction block now occupies. They are now loose under the junction block cover. How does the factory manage those in the newer trucks?
This is as far as I've got so far. The harness is now tucked away till I can figure out how it's routed to the fans themselves, get the pin in the PCM, and the AC clutch spliced in.
ScottyBoy
Shreveport, La
Yes, the extra relay I added in the harness is needed to convert the AC compressor clutch trigger wire to work with the fan harness. And yes, its a pretty tight fit under the fuse block stuffing the harness and relay underneath the fuse block, but it just BARELY fits. On the 00-02 trucks, there is no AC pressure switch that sends a signal to the ECM. But there IS a pressure switch on 03+ trucks. Since that pressure switch is there, it sends a signal to the ECM to let the computer know when the AC pressure is high enough to trigger the fans to turn on. Since the 00-02 trucks do not have this, you have to tie into the AC compressor clutch wire instead of the ECM. The clutch wire is positive, not negative. That's why the extra relay is needed, to change the positive signal from the clutch wire to negative. Then that relay sends a negative signal to the 05-06 OEM relay block which ends up turning the fans on whenever the AC compressor is running. This works okay for the MOST part. The ONLY drawback is it will still trigger a fan to turn on in cold weather when you have the defroster on, because the compressor turns on when the defroster is on. I hope all this makes sense. But I have had my fans wired like this since 2010 and they have worked fine ever since, other than a fan running un-needed in colder weather when the defroster is on.
That’s how I did my 02. It’s been fine for years.
You won’t be able to do it exactly the same as the 05-up because your wiring harness isn’t the same. Do the best you can and don’t stress over it is my suggestion unless you want to find an 05 harness for the entire front end of your truck and take forever to switch it over and hope everything still works afterwards. :p
What would happen if you disconnect the ac compressor during the cold months? Then it wouldn't trigger the fan to come on once the defroster was turned on. When I was younger I used to unplug the compressor during the cold months with no drawbacks.
ScottyBoy
Shreveport, La
In most climates, it would be just fine. But in very humid climates, like here in Louisiana, the AC compressor comes on to help the defroster to decrease humidity, and it that actually helps a LOT. But in drier climates, you will most likely not see any issue.
Another option would be to wire in an toggle switch on the AC trigger wire on that fan relay. Turn it off in cold weather, but then you will have to remember to turn it back on in warmer weather. I just left mine alone, and the only real drawback I've noticed is that sometimes in colder weather (belowe freezing) my truck takes a LOT longer to warm up.
Matthew Jeschke
Sahuarita, Arizona
@ScottyBoy makes perfect sense about the AC Compressor clutch. If I have to tear apart the AC system again I'll add that pressure sensor maybe lol
My friend has a 2005 Silverado. I asked him if I could look under his hood and he didn't even give me an answer. He kind of looked at me weird :oops:
ScottyBoy
Shreveport, La
I remember reading in a thread over on Performance Trucks about adding a pressure sensor and then reconfigure the computer software to recognize it and everything. So it can allegedly be done, but in my opinion it's not worth the hassle. Like I said, I have been daily driving my 2001 like this since 2010, so that's 15 years now and it's been doing perfectly fine except for VERY cold days, which honestly doesn't even happen that often in Louisiana. And with you being in Arizona, I'm guessing you would not have very many sub-freezing days as well. The ONLY difference between the harness you have and a completely stock harness in a 2005 is the AC trigger. Yours is now triggered by the AC clutch wire, (so anytime the AC compressor is enagaged, one fan wil be on) and a 2005 is triggered by the ECM, and the ECM triggers it when it senses the AC pressures are above a certain threshold. Both harnesses are triggered exactly the same as far as the temperature. When the ECM senses that the coolant temperature is above a certain threshold, it triggers both fans to come on at low speed. But if one fan is already on because of the AC, then the other fan will turn on at high speed, therefore having both fans on at high speed. When the AC is off and the coolant gets up to temperature, both fans are wired in series, so they come on at low speed.
Also, if you haven't already upgrades your alternator, I highly suggest that you upgrade to a more powerful alternator. I upgraded from a 130a to a 145a, and I still sometimes see a sharp voltage drop for a second when the fans kick on. But that usually only happens at idle. At higher engine rpm's, I don't notice any voltage fluctuations. I also added a smaller alternator pulley to help the alternator spin faster, which helped marginally but not a lot. I bought it on Ebay for like $15 shipped, so at that price it was worth it l guess.
Matthew Jeschke
Sahuarita, Arizona
I got everything wired up... @ScottyBoy Did you intend the AC clutch signal wire be fed through the supply / power side of the relay to the compressor clutch? I hooked it to the control / trigger wire for clutch relay and it doesn't work... Otherwise I can short the relay and the fans go on.
I can also command the fans on from the PCM (although not individually, as I see only the low temp fan is wired up in harness). I just cannot command on the fans when the AC turns on.
BEEN UPDATING MY NOTES AND SAVING THEM HERE AS I FIGURE THIS OUT.
Studying schematics for the 2005 Tahoe. I think I may have a less expensive way to do this...
The pressure sensor is a voltage divider. It's giving a fraction of 5V proportional to the pressure. Not sure what the impedance of the sensor is, but probably doesn't matter. I'll try a 100k ohm potentiometer
PCM Pinout
C1 pin 45 (Gray) is the 5V reference (Supply voltage)
C2 Pin 14 (Red/Black) is the signal being read (divided voltage)
C2 Pin 80 (Black) is the reference ground
I can connect a potentiometer in there and figure out which voltage commands on the fans. Only thing is, I'm not 100% sure but assume the PCM looks at the AC clutch being commanded ON AND not JUST the pressure. Otherwise, we're back to needing a relay.
If this works a couple cheap resistors can be used in lieu of the relay... additionally, I'm assuming you only used the low temp fan trigger from PCM as you had to splice the two fan relay triggers together to use the relay method w/ AC clutch.
Found sensor on Rock Auto. It's a three pin confirming schematic above. I think those wires are dedicated to just that sensor (the reference power is not shared with any other sensors?).
I hooked up a pot to spare PCM in my lab and it worked as I'd thought. Additionally, given HPT looks like the PCM does discern Pressure sensor from AC clutch command signal. Tomorrow I can try it in the vehicle with the potentiometer.
I'm guessing 50% divider say two 50kohm resistors (2.5v) will work fine but don't have the scalar / multiplier for voltage to PSI on the sensor.
This webpage says 0V is 0PSI and 5V is roughly 430PSI.
Stock settings for pressure AC refrigerant pressure command on in PCM from 2005 chevy tahoe.
DTC0530 Less than 100mV or greater than 4.9v for 5 seconds trips code.
This indicates the divider may have a resolution of 2%... 1:500
It'd be nice to have one of the sensors available to measure impedance.
PCM PINOUT 2005 versus 2001 Tahoe:
5V Reference
C1 pin 45 (Gray) 2005 5V reference (Supply voltage) for AC pressure
C1 pin 45 (Gray) 2001 Fuel Tank Pressure sensor
C1 Pin 46 (Gray) 2005 Fuel Tank Pressure 5V reference
C1 Pin 46 (Gray) 2001 Throttle Position Sensor 5V reference
SIGNAL
C2 Pin 14 (Red/Black) 2001 UNPOPULATED
C2 Pin 14 (Red/Black) 2005 is the signal being read (divided voltage)
REFERENCE GROUND:
C2 Pin 80 (Black) 2005 Reference Ground AC Pressure
C2 Pin 80 (Black) 2001 Fuel Tank Pressure Sensor
C2 Pin 64 (Dark Green) 2005 Fuel Tank Pressure Sensor
C2 Pin 64 (Dark Green) 2001 Fuel Tank Pressure Sensor
I need to find out if low reference and 5v reference lines have to be paired. Not sure if they're isolating those lines to reduce noise (is what I'd do if I designed the PCM).
It does appear as though they do splice the reference lines though. Not ideal but really probably not to big an issue.
Matthew Jeschke
Sahuarita, Arizona
After some study the low speed and high speed fans is fairly simple in concept. Low speed connects fans in series (voltage divides proportionally to motor load / size).
High speed switches the ground connection order (middle relay), establishes a connection to positive voltage (fan right) Coolant Fan Relay 2 (left)... This reconfigures the motors to be in parallel, each receiving full alternator voltage.
I'm going to try and rig this up so there's no low and high speed mode. I drive off road in extreme heat and definitely need the high speed mode. Right now as configured the harness works but only uses high speed when AC is turned on.
Unfortunately, I cannot reconfigure the PCM to accommodate the high speed pin. It's pin is populated with something else on the 2001 Tahoe.
I'm not sure how to do this w/ risking blowing up my PCM... as the trigger wire for the AC clutch relay is in the harness from @ScottyBoy is tapped onto the supply line for the AC clutch fused at around 140Watts. On a side note, maybe worth trying to put a resistor in series with the relay in harness to limit current on that line. Could be dumping a fair amount of current through the coil on the relay (typically the relays like 250mA if that, I've not measured draw with relay in parallels to AC clutch power). If I splice that into the same line as the trigger wire for the Low speed fan from PCM then I created a ground path from much more powerful circuit (AC clutch circuit) through the PCM which could easily fry it.
I may just delete the AC clutch relay all together... AC won't cool as well till engine is up to temp but should work fine / not hurt anything. Then splice blue 473 to 335 D-green above so I get full fan power when fans are commanded on instead of only when AC is commanded on.
Another thought is a thermostat switch. I could just put a thermostat switch on the radiator for say 215F and splice that into the high speed relay.
This is a bit jankier than I'd hoped for unfortunately.
Studying differences between 2005 Tahoe and 2001 in HPT.
If I compare the PCM harnesses C1 and C2 the correlate with the terminology above. I think what happens if if you change these settings it reconfigures those pins and executes the logic for the pressure sensor.
My 2001 Tahoe
The 2005 Tahoe
I went out and loaded up a tune with the "Recirculation Fitted" set to Fan #2... I think I had some success! When using the scanner I commanded Fan #2 on and the recirculation door moved! This tells me that you can get control of Fan 2 from my 2001 Tahoe. However, it may require sacrificing "recirculation" functionality of HVAC and or coupling the fan and the recirculation door.
2005 C2 Pin 33 High speed Fan mode
2001 C2 Pin 33 Recirculation Actuator Control
Beyond that there appears to be a bit more to the recirculation mode I maybe sacrificing if I switch that setting. I'm not sure what C2 Pin 11 "High pressure recirculation switch" is about.. is that the defog / defrost function of the AC?
I can also of course command on fan one and the fans turn on (low speed).
Analog Cycling is a AC that operates on discrete (on / off) pressure switches to control the pressure in the line set.
Serial Cycling is an AC that operates off of specific high side pressure to control pressure in line set.
Pretty sure I cannot get away with changing the one setting to Serial Cycling so getting the PCM to control the fans off line pressure probably not happening. Maybe more grief than worth it to convert the signals of analog to be compatible with serial cycling controller paradigm.
RANTING... Why on earth did they EVER design this PCM with AC controls in the engine controller. *Facepalm* got to be the dumbest thing I've ever seen other than perhaps controlling cooling fans which double as condenser fans. GM could have done this WAY easier with a discrete line to the PCM to request fans on or even some wizardry on the fan relay trigger, maybe I a serial communication but that seems like overkill.
ScottyBoy
Shreveport, La
You are WAY overthinking all of this. Are you really willing to sacrifice you AC circulation function JUST to have the PCM trigger the fans, and not the AC compressor trigger the fans?
Yes, the temp relay commands them on at low speed. But low speed is more than enough to cool just fine in most situations. Thats how GM designed it to function, and it's been working just fine on every GM truck since 2005 that came with electric fans. You only need high speed when it's warm or hot outside. And of COURSE if it's over 75 or 80 degrees you will have your AC running. The AC compressor will trigger them to run at HIGH speed. I have been daily driving my truck with it wired like this 2010 or 2011 and it's been working just fine. And trust me, these brutal Louisiana summers are NO joke. It gets pretty hot down here, regularly in the triple digits in July and August. And my fans have performed flawlessly and kept my truck cool and my AC blowing cold. EVERY single harness I have sold with an extra relay spliced in for the AC compressor clutch wire has worked the same way. Others like Rocketman and everyone else with a 00-02 can confirm that their fans work the same way and they work perfectly fine like this. If the AC pressures are high enough to trigger the fans on a 2005, then the compressor WILL be running. Thats why it's FAR easier to just tie into the compressor clutch with on a 00-02 trucks instead of a ton of extra wiring and programming to get it to work.
But if you really want all the headaches of completely rewiring your truck to have the computer trigger the fans, instead of the AC triggering the fans, then go for it. Let us know how it all turns out in case anyone else wants to end up doing all of that.
THIS^^^^^
johnsonwillie199
