Differential Cover Fitment - 9.5 inch 14 bolt
AirJordan613
Northeast Ohio
Foggy
KS
I purchased a similar one for my 8.6" 10 bolt rear. The company offered
the standard one and a low profile one too. So I did the low pro one.
It did NOT fit... But I have larger aftermarket sway bars...
You might do some more searching to see if a low profile one is made.
I don't remember the brand.. It wasn't a brand you could get from Summit or Jegs..
Maybe something like "covers.com"... I also have the deep alum trans pans
from them
Foggy
KS
I have a 2009 Tahoe with the 9.5 inch 14 bolt rear end. Does anyone know if this differential cover (or any other aftermarket) will fit? I understand it can be tight with the rear swaybar. Thinking it would be nice to have a drain plug and improved cooling. TIA!
I'm pretty sure that one won't fit. Esp with having the preload bolts.
You really should not need anything extra with your 14 bolt.. It's way stronger
than the AWD 10 bolt rear ends .
Just change the fluid more often.. Yeah it 's messy !!!
j91z28d1
I thought that really nice air cooled banks one was available for the 14bolt. but sadly not the smaller 10 bolt that needs it more.
JamesinAbilene
