Need support. Just found out my radiator is leaking
iboughtatahoe23
iboughtatahoe23
im reading the most common point of failure are the plastic end tanks however i didnt see any cracks
iboughtatahoe23
iboughtatahoe23
Only place I can see liquid or coolant is under the radiator in the little tray (think that’s what it is) and than some on the splash guard
iboughtatahoe23
iboughtatahoe23
I think I found it? Seeping through the side tank.
iboughtatahoe23
iboughtatahoe23
The shop I go to is thinking the same thing. But we just looked around while it was running and noticed it was seeping. Now I’m deciding if I should order the radiaotor or not
iboughtatahoe23
iboughtatahoe23
I squeeze the hose and there no pressure in system and coolant still drops after a drive, and after it cools down… those seep spots look the same. Not really justifying that much coolant loss (an inch or so under the full when cold line)
I’m kind of waiting to order because I wanna make 100% sure this is the right decision to make
EddieC
I had a three year old Acura radiator spring a leak. It was nothing to drain and take it out and to a radiator repair shop. It was no big deal and didn't cost much *at the time). They boiled it out, soldered the leak and pressure tested it.
Honestly the hardest part was draining and containing the fluid avoiding contaminating the area but it worked out well.
Good idea on the water pump. Now would be the perfect opportunity. I was surprised how easy this water pump is to install vs other makes. The 5.3l is super mechanic friendly- thank you Chevrolet.
iboughtatahoe23
iboughtatahoe23
So Is watching a video for a 2014-2018 Silverado gonna work cause I can’t find a decent video that isn’t an hour long for my year Tahoe
iboughtatahoe23
iboughtatahoe23
I hear that’s a little more difficult than the radiator because you have to torque down the bolts to a certain spec and there’s a certain pattern they go on I was told? And use paper gasket
watch it be the head gasket lol #totaled
as far as options on radiators as long as it has a transmission cooling option the oil cooling option does not matter the lines would just not be used. so you can use it with or without oil cooling.
water pump I wouldn't even blink a eye at unless it has over 160k on it, then it's a matter if it is leaking or not. when they go out they tend to start leaking from the bearing seal which you will only see from the bottom with a flashlight and tilt mirror. Otherwise when they fail they do so in dramatic fashion like blowing out the gasket. seeing one with worn out fins (internal) is pretty rare unless you have been running straight water for a long period of time with corrosion eating away at it.
iboughtatahoe23
iboughtatahoe23
I got 178k on my odometer. No clue if it has been changed before. Doubt it
scottd
