iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 1,133
- Reaction score
- 570
im reading the most common point of failure are the plastic end tanks however i didnt see any cracks
Do you know what core thickness I am supposed to get.Yes. Every hose and line. Match it with your year and model but verify number of ports.
NegativeDo you know what core thickness I am supposed to get.
grabbed the thicker core.... now wondering if i should do my water pump as well.Negative
and every coolant carrying hose on the vehicle if they are old.grabbed the thicker core.... now wondering if i should do my water pump as well.
currently just the radaiator and got some metal t connetorsand every coolant carrying hose on the vehicle if they are old.
I hear that’s a little more difficult than the radiator because you have to torque down the bolts to a certain spec and there’s a certain pattern they go on I was told? And use paper gasketGood idea on the water pump. Now would be the perfect opportunity. I was surprised how easy this water pump is to install vs other makes. The 5.3l is super mechanic friendly- thank you Chevrolet.
as far as options on radiators as long as it has a transmission cooling option the oil cooling option does not matter the lines would just not be used. so you can use it with or without oil cooling.watch it be the head gasket lol #totaled
I got 178k on my odometer. No clue if it has been changed before. Doubt itas far as options on radiators as long as it has a transmission cooling option the oil cooling option does not matter the lines would just not be used. so you can use it with or without oil cooling.
water pump I wouldn't even blink a eye at unless it has over 160k on it, then it's a matter if it is leaking or not. when they go out they tend to start leaking from the bearing seal which you will only see from the bottom with a flashlight and tilt mirror. Otherwise when they fail they do so in dramatic fashion like blowing out the gasket. seeing one with worn out fins (internal) is pretty rare unless you have been running straight water for a long period of time with corrosion eating away at it.
naah, just look harder with a flashlight, take that splash guard off and look up.Soooo pressure test and some UV dye?
