It Rained so 2015 Yukon won’t start, Help!
Yukon2703
As always whenever we get wet weather our 2015 Yukon won’t start. The dash goes funky, all the warning lights, multiple service issues on screen like
-service airbag
-service trailer brake
-service steering column lock
-service front camera (doesn’t even have one)
Sometimes dash will go black like dead battery, won’t roll over at all then dash will go funky. Weirdest of all it will start off factory remote start on fob. I managed to get the scan tool on it and this is everything it gave me
Service steering column lock
Service airbag
Service front camera
C0110-61 pump motor circuit - stuck
Erased and all went away
U0140-00 lost comm with bcm
U0155-00 lost comm with IPC
U0170-00 lost comm with pass presence module
B2575-04 headlamps control circuit open
B2645-07 ambient light sensor high voltage
B2699-04 right headlamp circuit open
B305A-00 no response from steering column lock received
B3111-00 keyless entry transmitter 3 battery
B3935-00 transponder authentication
B3979-00 no environment identified received from hvac module
C0755-29 right front pressure sensor to few pulses
C0750-29 left front tire pressure sensor to few pulses
C0760-29 left rear
C0765-29 right rear
U0078-00 control module communication low speed CAN bus off
U0164-00 lost comm with HVAC module
U0208-00 lost comm with seat memory
U0236-00 lost comm with steering control module
Erased and all gone but
B305A-00 & B3111-00
U0029-00 MOST bus performance
Erased and went away
U0078-00
U0151-00 lost comm with inflatable restraint sensing and diagnostic module
U0155-00
U0184-00 lost comm with radio
U0198-00 lost comm with telematic control module
U0230-00 lost comm with liftgate control module
Erased all went away except
U0184-00 & U0230-00 stayed
This has been a major pain in the hole, I’ve seen many other write ups with similar problems but I’m yet to come across a fix, has anyone managed to find a fix to this extremely frustrating problem. Any help would be appreciated, doing everything I can to avoid a trip to hells gate (local dealership).
Thanks
PG01
Up here to the right
So, next time its dry for a few days and the truck is dry and acting ‘normal’ park it in the sane spot your issue happens when it rains then bust out your garden hose and try to wet down the truck 1 section at a time. Do the passenger side roof, windshield, hood and fender…. See if it starts, driver side …. Etc etc. but wait a day or two so that the trucks acts ‘normal’ and then do the other side.
my guess is you are getting water in the cabin under the dash or somewhere or under the hood to the fuseblock.
Y
Yukon2703
I’ll absolutely try that, I’ve already went down that road a bit, had shark fin off and made sure it was sealed up good, I had one guy talk about wiring issues under dash pad next to windshield so I removed it and no water or issues in there. But I’ll gladly try it out, gotta figure something out. Thanks for the ideas, I appreciate it.
Y
Yukon2703
It starting normally with the Key FOB throws a wrench in all my suggestions.
I’ll gladly take all suggestions, I went this morning and tried it and no go again. Key fob wouldn’t work either this time so it’s just dead in the driveway.
Z15
Michigan ,USA
May not be related to your situation but I'll relate this experience a coworker had.
His 1990's Mercury Marquise would not start when damp outside. Someone suggested we spray down every electrical connection and ignition related wires with WD40. We did that and it started right up. Back then it was easy, just replace all the ignition parts and solved problem. Nowadays, any wire can be the culprit.
WD40 = Water Displacement formula #40
Geotrash
Dave
Richmond, VA
-service airbag
Service airbag
C0760-29 left rear
C0765-29 right rear
B305A-00 & B3111-00
U0078-00
U0155-00
Thanks
I'd start with a good cleaning of all of your ground points in and near the engine bay and BCM. After that, I would suspect the BCM or at least its connections. The WD40 on the BCM main connector is a good idea to try. Given that the behavior is different when using the key fob, I would trace the wiring from the start button to the fuse block and BCM as well.
I agree with Dave, pop the hood take the battery cables off, start wiring brushing the contacts and wire brush any power or ground spots you can find in the engine bay, engine, frame grounds, under the body, etc.
look closely for any visible signs of corrosion or rust.
then you will probably want to start looking for any visible signs of rubbed or exposed wiring front to back
get a flashlight and start looking everywhere under the truck
Geotrash
Dave
Richmond, VA
One more thing I'll add: If the temperature of the vehicle is cooler than the air temperature, as often happens first thing in the morning, then the humidity in the air condenses onto the cooler surfaces of the vehicle, even under the hood. This condensation can cause all kinds of problems, including partial shorting of circuits, and otherwise interfere with any electrical circuits and wiring exposed to condensate. Wes's advice is also sound, in my opinion.
Y
Yukon2703
Update, I got home today and tried to get the Yukon into my garage to see if I could at least dry it out. The dash stayed totally black, when I’d hit the start button I could here it clicking but nothing, I checked battery and it had full charge, tried the fob and door locks worked, headlights, tail lights and all cabin lights came on and off, noticed that the outer brake light (the red section) of the drivers tail light wasn’t coming on, tried to see if fob would start it but nothing. It won’t even let me get it into neutral to push it into the garage, can’t find an over ride for the shifter. Hopefully tomorrow it’ll dry out some and will start for me or at least let me get it out of neutral, fingers crossed. GM should be ashamed of these issues, I’ve seen multiple threads with the same issue with no fix besides “ I took it to the dealership and they kept replacing parts until it started”, I’ve been a lifelong gm buyer but why would a person even consider buying a new one at there inflated prices with more of the subpar technology in it?
MD-Wood
Re crimp your battery cable ends. Hot/ cold dry and humid all have effects on these ends and that year had connector issues.
Hitman
-service airbag
Service airbag
C0760-29 left rear
C0765-29 right rear
B305A-00 & B3111-00
U0078-00
U0155-00
Thanks
In my 2015 yukon XL I had a similar issue water was some how getting into the truck, the passenger floorboards always wet. I tried everything to find the leak, cleaned sunroof drains, etc, looked at AC coil nothing, taped up some holes in the fender by hinges, sealed around the battery area, so on.
In all of this I pulled off the passenger door sill and trim then lifted the carpet, in the floor rail there is a wiring harness and connector. It was full of water.
I never had anything short out but always on my mind when it would happen.
Maybe this might help your situation.
Y
Yukon2703
I managed to get the truck into the garage the other night, it started but most of the dash wouldn’t light up. I pulled it inside and decided to unhook the battery cables and let it sit to dry for a day or two before going back to it. When I walked behind it I noticed the out led ring of the drivers tail light wasn’t working, I bumped it and as you can see in the video it just kept flickering. I left it to sit for a couple days then it started right up and worked as it should, I drove it all day yesterday and it worked fine and I parked it in garage last night. Raining this morning, drove it for 10 minutes then parked it back inside, went out a few hours later and back to the no start issue, dash lights up but nothing when hitting the start button. My next plan is to remove tail light to see if water is getting in there.
Y
Yukon2703
Latest update, still no luck with the Yukon, I ordered a new tail light that will get put in this weekend. I’m wondering if there is anyone that can give me an idea of where modules are located on the truck that could get any water on them from driving or just sitting out in the rain. I’m just going to go module by module making sure they’re good and clean, spray all connectors with contact cleaner and give everything a healthy does of dielectric grease before I put it back together. Hopefully this will help me find something. Thanks in advance for the help.
Isaac2468
Just wondering if you had any luck with it by now? I have the same exact issue for over a year now and can’t find it!
Acruz
Having same issues any information would help
Thanks in advance
Acruz
Hi
Any updates im
having same issues wondering if u solve the problem
Thanks in advance
Y
Yukon2703
I Haven’t found the issue yet but this weekend it rained all weekend long so I parked the truck outside and left it, I went out after a day full of rain and the truck started up. This leads me to believe that water is getting in somewhere while driving. Also to everyone else that’s experiencing the same issue here’s a question, have you done the transmission in your truck yet? I found one thread on electrical issues and bad grounding and if any major work has been done where a ground could have gotten broken or missed being hooked back up. My transmission was done last year and now I’m wondering if I had these issues before hand, I can’t remember but I’m soon to check to see if anything got broke or missed when the tranny was done. Again all help is appreciated, thanks.
Tultruk
We had all the same codes and glitches on dash after heavy rains. it ended up being the wiring harness in rear bumper with all the proximity sensors in it.
Y
Yukon2703
Dodn
Did you replace the harness or repair it? How were you able to tell it was the harness, was there visible damage to it or just appeared to be bad and hoped for the best? I’ve been trying to fix this issue for 6 months now
Charlie21ny
