Oil pressure low
Angelo217
Angelo217
Those value look perfectly normal for the mileage you have. What does the pressure goto when cruising at 55pmh? How about idle to 35 mph? Do you have a standard 3.73 rearend?
Idk it’s like, maybe around 30 ish as of right now it’s acceptable since like I said I just did an oil change. Drove 300 miles around Galveston and Houston. HOT idle after 2 hours of driving with this fresh OC in idling just a hair above 20 PSI. Normally running idle to 35 it’ll shoot slightly above 40 psi. And it’ll run at 30 or so idling at 55 psi. Rear end not sure. It’s a z71 has the locking rear differential via traction control button. It’s a 2WD
Angelo217
Angelo217
Mine was recently intermittently going down to 20 psi before I replaced the oil pressure sensor. Maybe the heat when the engine is warmed up is affecting the sensor but I don't know about the new oil/old oil aspect.
Is your pressure fine now? Post sensor replacement.
Angelo217
Angelo217
Another reason I bring this up is by comparison.
We have a second 2006 Chevy Tahoe 5.3 L, LT trim. it’s got 300k miles on it. 160k miles of straight neglect and abuse, as it is a work truck. Now my brothers vehicle. It makes fantastic oil pressure. Around 60 on the highway no problem. Idles at 40 all day long even on old oil.
This is mainly why im concerned about mine. As mine to my knowledge did not get anywhere near that level of abuse.
And by abuse I mean complete mechanical negligence until something broke basically. Very rarely did oil changes on it. (This was not my vehicle, I take care of my vehicles lol.)
petethepug
Michael
SoCal
If you overfill the oil after the motor is warmed up at idle and the pressure goes up by 5/10lb you can verify if the O ring on the oil pump is bleeding air into the system or … replace the O ring, it’s bad.
Be sure to drain extra oil out b4 u drive it. You could also swap out the oil pump and replace with a HD version.
DRLexpress
Wow, can't believe I never thought of that. How much extra oil does it take? Could you just park nose down on a hill or front wheels in a ditch, to get O-ring under oil?
mattt
My 2004 with high mileage was doing the same thing on the original 5.3 engine. What I found out over time, is it had what started out as a very small coolant leak from a Castech head and when the oil was changed, it would return to better oil pressure. Over time, and as miles added up the oil was being compromised and polluted with just a little bit of water/coolant. As time went on, and the leak got worse, the time period of good/standard oil pressure became shorter and shorter since the oil was being compromised quicker.
When the engine is cold, pop your oil cap off and look on the underside/inside the cap. Do you have what looks like droplets? Sometimes you can even see evidence of coolant pollution in the fill tube that the cap screws into. That is what I observed and found out on my Tahoe, YMMV.
I have an old thread here from years ago asking the same thing as the original poster in this thread.
I think that's what happened to my Express van. Had the 4.8 with the 862 heads--which are known to be prone to cracks. When i sold my van the oil pressure was basically at 0. 20200114_190430.jpg20200114_190420.jpg
Your oil pan might have similar sludge too.
Angelo217
Angelo217
I think that's what happened to my Express van. Had the 4.8 with the 862 heads--which are known to be prone to cracks. When i sold my van the oil pressure was basically at 0.View attachment 443066View attachment 443067
My oil pan was very clean. Literally had to do virtually 0 cleaning when I dropped it. Was the original gasket btw. Hasn’t been dropped/ cleaned for 230k miles.
Angelo217
Angelo217
I’ll check this for sure. I’m fixing to throw in my new oil pressure sender sensor. Along with intake manifold gasket, because for some odd reason my sensor is a different size from the factory sensor. 1” 1-16 or whatever it is
Angelo217
Angelo217
I’ve already replaced my o ring. Red to red. Mahle, red was in there replaced with a red o ring. My o ring really wasn’t in the worst shape, was just flattened. No cracks or major deformities. And oil pressure is maybe slightly better on average after changing that out 5k miles ago.
There's a special socket for the sender. Although a standard socket may work, it could damage the electrical connection on the sender when it's tightened down, and may experience interference with the intake manifold.
Angelo217
Angelo217
I will take a look when it’s cold again. Haven’t lost any bit of coolant over 6-7k miles or so but I will look thanks man
Angelo217
Angelo217
There's a special socket for the sender. Although a standard socket may work, it could damage the electrical connection on the sender when it's tightened down.
Yea I have the special socket for it at my shop. It works on the new OEM delco one I just bought, but won’t grab on the existing sender that’s in my motor right now for some reason… thinking the previous owner already tried this LOL. We’ll see what I got myself into. Worse comes to worse I’ll rebuild this one or get myself another 5.3. But I’ll try and bring this one back around.
Angelo217
Angelo217
Appreciate yall for the help. Also another mention about my rear main it’s absolutely just puking at this point. And im honestly really pointing my finger towards that. When I park oil is just all over my bell housing, watching the drops of oil fall down every 2 seconds after parking.
rockola1971
Indiana (formerly IL)
How much oil do you have to add every week and month?
Buford bubba
