5.3 engine tick ONLY in Drive/Reverse
Bama704
Charlotte, NC
I all,
I have a 2013 Tahoe LTZ 5.3 with 171k. The issue just started about 100miles ago. When I start the tahoe cold or warm and am in park the engine is quiet, no knock or tick, however once I put it in gear and accelerate it starts to make a ticking noise. The tick follows the rpm. I also only hear the noise on the drivers side. Once I place it back in park and open the hood to inspect it's quiet again. Has anybody ever experienced something similar?
I replaced the oil sensor at the back of the engine this time last year because loss of oil pressure light. I say that just to list things I have done so far to the tahoe. Oil pressure is good at start up and while driving. 25-30 on start up and 40 while cruising.
Geotrash
Dave
Richmond, VA
I all,
You're in the 2007-2014 section so you might get better info in the previous gen section. That said, record a video on your phone, upload it to YouTube with public permissions and link it back here. We'll help you figure it out.
Bama704
Bama704
Charlotte, NC
What about the starter would cause that noise? You thinking if I dropped a new starter in the noise would go away. Not holding you to it, just curious.
petethepug
Michael
SoCal
Exhaust manifold gasket(s) my friend. You’re being steered in the right direction even though you drove to the wrong forum year.
Geotrash
Dave
Richmond, VA
It's in my post. The return spring fails and lets the drive gear tink against the flywheel.
Yes. I'm betting it would solve the problem. If you can get a video from the pax side it would help confirm.
Geotrash
Dave
Richmond, VA
Thought of that but it's too irregular and I had the EXACT same sound on my 2007. It was the starter. Common problem on these.
Bama704
Bama704
Charlotte, NC
Thanks for all the helpful replies, I will start looking at the starter first, then go from there if that's not the fix.
I thought this was the 07-14 Tahoe section, with a 2013 Tahoe wouldn't it fit right in? Where should I have put it?
You're in the right section for your 2013, but your signature can be misleading. If the 2013 is in your fleet, consider adding it to your signature. Or if you've upgraded to the later model, edit your sig.
Big Jim
