RooTBeeRthe1st
I can't imagine the commitment it takes to drive something that low around Louisiana roads.
that low life or no life I guess
It's bagged. Aired all the way up, it's higher than stock. He has the ride height pre-set, but he actually can drive and turn with it as low as physically possible. He doesn't drag it and all his wheels clear. That's more than I can say about mine.
Geoffsfas10
St. Louis
Swapped into the new camposition sensor tonight. Not too bad a deal overall. Was actually easier to pull the intake tube and go at it from above with a long shaft flat head. The old came out in pieces, so maybe it was what was actually jacked up. I drove it around the block and then went grocery shoppi g. So far no light, fingers crossed its good tomorrow. I should know quick since it was all sorts of unhappy today before the sensor
blackelky
Ordered GM Part # 15055343 and 15055342 and the dorman hoses with metal y Dorman 626-553. Because Doubeleive
scared the **** of me that they're going to fail soon lol. Hopefully get them swapped out Friday
Now the temp guage fluctuates between 210-230 hopefully the air is just bleeding out of the system
j91z28d1
no clue. New GM coolant tees don't leak lol I'll pop off the cap and let it run for a bit heat on high
forget the exact bleed procedure for an ls, but it's super simple like idle till up to temp, shut down till it cools completely. top off res and done.
could be the stat. ls's are weird and have the stat on the cold inlet side of the engine and the temp sensor is on the opposite side in the head. so they do odd things sometimes.*edit* what I mean by that is there's some time to equalize Temps between everything because of the placements. it might just be you didn't pay attention to it before as much and didn't notice the cycle.
if you do change the stat, only use oem. I'm pretty sure it's made by Mahle/Clevite. motor rad seems to have bought out every other brand name. they just feel cheaply made and I've seen people test the Temps and they vary alot.
blackelky
I just changed the thermostat and hoses thermostat cover
j91z28d1
ahh. did you go from oem or aftermarket stat?
probably not a big deal
blackelky
so you did more than just heater hoses......
drive it up on some ramps or jack up the front, start it up, let it cycle the thermostat, top off.
if that doesn't work then you got a funky thermostat.
That wasn't all today. I did the radiator hoses and tstat when I first got it last year..anyway i opened the reservoir and let it run. All good now.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
You got to rev it up to around 2 grand or so and get that circulation going though everything. Glad it's ok now. When I did my water pump a month ago I let it run to operating temp with the cap off topping off as needed. But I had 0 heat. Once I revved it up for a bit it kicked right in. Got to blow all that air out.
blackelky
I took a trip to VA today and when I undid the cap there was a lot of pressure from the air bubbles that got released.
Escalade2007
