SOLVED - New engine with DOD delete and Cam Motion cam - valvetrain noise normal?
bcbickers
Conroe, TX
Greetings everyone!
My #6 lifter collapsed (see this thread), so I went ahead with a full rebuild: refreshed aluminum short block, DOD delete kit from Texas Speed, a Cam Motion Stage 2 truck cam with their beehive valve springs, and a Blackbear tune to make it all run right. Now that it is back together, I swear I can hear the entire valvetrain spinning, chain and everything. It sounds a little like a modern diesel or maybe like it is low on oil (oil level is fine, though). The engine is very 'staccato' now, if that makes any sense. Almost like I can feel every valve event and rotation of the cam. The valvetrain noise very pronounced when the engine is cold and lessens a bit when it warms up. The engine builder asked me to drive 500 miles, then change the oil and see if the noise is still there.
The Cam Motion camshaft I chose has a 115 LSA with .553 of lift, so it should feel just like a stock engine, right? Everything is actually perfect, save for the noise. Tons of low end power and pulls strong in the midrange. It just sounds odd and sort of drives/runs funny. For those of you that have an aftermarket cam, do you have any kind of valvetrain noise or experience any of the issues I mentioned here?
Foggy
KS
That cam will NOT feel just like a stock cam/engine
Post the specs on that cam please...
IF you didn't have it tuned AFTER the cam install, it needs the tune updated/changed
to deal with that cam
Foggy
KS
Greetings everyone!
I looked up that cam (hopefully correctly)
It's a 206/210 duration with 115 LS and 553 lift
That will NOT behave just like a stock cam and will need to be tuned accordingly.
That's bigger than a stock 6.2 cam... and you have 5.3 L
Foggy
KS
This cam is a great performance replacement for pickups and four wheel drive vehicles needing more power while maintaining excellent drivability, durability and fuel economy. This "high-lift" version requires our performance replacement beehive style valve springs.
The extra 15* of duration along with the added lift changes the entire airflow model
of the engine for the BETTER, but requires the tuning changes for sure.
Not sure if that will change your particular noises, but that thing can't be running
very smoothly at all.
Dustin Jackson
@bcbickers Like others have said, you said that you got a tune and a larger cam is the tune compensated for the cam?
You might just by hyper aware of sound of the engine. One of these engines in good condition WILL sound like a sewing machine and does make a lot of sound but that's normal. If you've ever listened to a brand new Dodge hemi 5.7 those things are loud its all clicky clacky.
If you think there is a problem try to get a good video of the sound and post it here
Foggy
KS
Your OE cam specs : 201 / 206 duration .481 / .481 lift
116* + 2* lobe sep
Which springs did you use ??????
bcbickers
bcbickers
Conroe, TX
116* + 2* lobe sep
Yes, the tune was written specifically for that cam with the DOD and VVT deleted. It actually runs quite well. The transmission tune is a bit aggressive for my taste, but the engine tune seems almost perfect. Blackbear is reviewing my logs, so I hope to have an update in the next week or so. The only thing wrong, if it is wrong, is the extra noise.
The springs are the Cam Motion beehives. Good for .570 of lift, iirc.
Blackbear wrote a specific tune for my setup (which is great, btw). But your 'sewing machine' comment is almost dead-on to how it sounds. If that's normal, I am fine with it. After 35+ years of driving, the noise I hear typically means low or no oil. And I do tend to be hyper-aware of how all my vehicles sound. Maybe too much so sometimes. :p This is the first time I have modded an LS, though. So I could just be paranoid/worried over nothing.
Would they have put in some sort of break-in or lower viscosity oil? He did tell me to change the oil at 500 miles.
did the "refesh aluminum shortblock" include decking the the block and/or heads? may need to revisit pushrod length and make sure preload is correct.
According to the work order, the block was 'line-honed, .020 in.' block and heads milling, factory stock head gasket. Nothing about pushrod length, though. The builder seemed very familiar with DOD deletes but did say he had never installed a Cam Motion camshaft before. I hope that is not a red flag.
... your 'sewing machine' comment is almost dead-on to how it sounds. If that's normal, I am fine with it.
LSs are known to have the sewing machine sound, but it's usually just on larger and/or aggressive cam profiles. I wouldn't consider yours large or aggressive.
Possibly. A short cycle oil change after a rebuild is necessary to get the break-in metals out.
So, the deck AND the heads had .020" taken off? I can't speak for Cam Motion, but it's common for larger aftermarket cams to have a smaller base circle on the lobe, often .050". This means you'd need a .025" longer rod (half of that .050" diameter). Stock is 7.380", so you'd need a 7.405". Aftermarket rods are commonly available in .025" increments, so you'd use 7.400". BUT, if the deck and head both had .020" shaved, then you'd need to subtract .040" from the push rod length, yielding a 7.360". I'd go with 7.350" or 7.375". LS lifters have a wide acceptable preload range.
You really do need to know your cam's and engine's specs. I have a hard time believing they took .020" off the deck. Unless they used shorter rods or pistons. I can see .020" taken off the heads. That would put you back at 7.380" push rods, meaning stock length.
randeez
south florida
Doesn't have much to do with the type of cam, unless it's ground on a smaller base circle or some weird shit but cammotion is using new blanks so no reason to.
like @iamdub said above most dod kits will come with 7.400s or reuse stock...but it should be checked or verified during installation. There's a pretty narrow window. You don't necessarily "set" the valve lash you get the correct push rods that give you .050 past zero lash when the rocker arm bolts torque gets to 28ftlbs iirc, which corresponds to 1.25-1.5 turns past zero lash.
Also yes, the extra noise could just be from the increase spring/seat pressure compared to the stockers
Geotrash
Dave
Richmond, VA
Greetings everyone!
I have that same cam and it’s quiet. Standard pushrod length also. I suspect that if the heads were milled, your lifter preload is off and you’ll need to make adjustments to pushrod length. More when I have more time…
Foggy
KS
Very Good Point !!!!!!!!!!!!!!!!
bcbickers
bcbickers
Conroe, TX
I may have left a comma off. The block honing and milling are separate line items on the work order. I take it to mean the block was honed .020 in. over, while the heads and block were simply milled to ensure a good fit. It doesn't say how much was milled off the heads and block. I'll check with the engine builder for more details.
That's great to hear. Everything I read about this cam said it is quiet, has good manners like stock, and didn't move the powerband really high in the rev range like some of the others do.
I think I will give it 500 miles then change the oil and see how things are. Blackbear's tune update may help as well.
Definitely see if the builder documented specifically what they did. If even just a cleaning pass to true the deck and heads, it's still something to account for. You can get a push rod checker tool for about $25. It's tedious work, but knowing is worth it.
Having said that, I checked every one of mine about a year ago and replaced the rods accordingly to tighten the variance range between them all. I have three different length rods throughout mine. But it's an original 200,000+ mile block and these engines are often "bowed" from the factory, making the corners lower by a few thousandths.
bcbickers
bcbickers
Conroe, TX
Thanks for the video and sound clip. Yours seems a little quieter than mine, but it could be me just being OCD or something. I'll try to get a quick video of mine when the rain lets up.
Candielaine
